Page 5 of 5 FirstFirst 12345
Results 41 to 46 of 46
Thread: 7.5 vs 8.8
  1. #41
    Join Date
    Oct 2004
    Location
    Farmingdale, NY
    Posts
    9,092
    Feedback Score
    18 (100%)
    Default
    I assume by 350t you mean 350 ft-lbs of torque?
    If done correctly a 7.5" can handle more than that.....
    I'm told mine will take over 500 in it's current form. The locking unit is rated for 800....
    Then again I see you were talking about the 7.8.....
    As said before a similarly built up 8.8 will be stronger than a 7.5 barring some part defect.
    -- 05 Mustang GT-Whipplecharged !! -- 87 5.0 Trick Flow Heads & Intake - Custom Cam - Many other goodies...3100Lbs...Low12's! http://www.fquick.com/V8Demon
  2. #42
    Join Date
    Dec 2005
    Location
    Bethlehem,Pa.
    Posts
    4,049
    Feedback Score
    42 (100%)
    Default
    I couldn't brake my 7.5,I tried.Of course its for sale!
    If you build it right it will not come apart.
    Old Grey Cat to this.88 Cat,5.0 HO, CW mounts,mass air,CI custom cam,afr165's,Tmoss worked cobra intake,BBK shorty's,off road h pipe, magnaflow ex. T-5,spec stage 2 clutch,8.8 373 TC trac loc,che ajustables with bullits on the rear.11" brakes up front. +
  3. #43
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,527
    Feedback Score
    135 (100%)
    Default
    I had a 7.5 with 3.45 gears from a Turbo Coupe.That thing took all the abuse I gave it,and never gave me a minute of trouble.
    '88 Sport--T-5,HURST shifter,Trick Flow R intake,Ed Curtis cam,Trick Flow heads,Scorpion rockers,75mm Accufab t-body,3G,mini starter,Taurus fan,BBK long tube headers,O/R H-Pipe, Flowamaster Super 44's, deep and deeper Cobra R wheels, Mass Air and 24's,8.8 with 3.73's,140 mph speedo,Mach 1 chin spoiler,SN-95 springs,CHE control arms,aluminum drive shaft and a lot more..
  4. #44
    Join Date
    Sep 2006
    Location
    Olathe, Kansas
    Posts
    2,408
    Feedback Score
    3 (100%)
    Default
    What about picking up a 7.5 out of a sn95 v6 stang, should swap right in, correct?
    Rear disc and all??
  5. #45
    Join Date
    Sep 2006
    Location
    New Jersey
    Posts
    67
    Feedback Score
    0
    Default
    Look..... you can make a 7.5 do crazy things if you build it right..... Take mine.... it's a 7.5 with a detroit Tru-Trac locker, Ford Racing 4.10 gears, Moser C-Clip Eliminators, Yukon Axles, T/A performance rear end cover with main supports and fully welded Axle tubes..... I am pushing over 500 RWHP and close to 500 ft. Tq. to the wheels with 295/45/17 M/T drag radials. CHE upper control arms and maximum motorsports lower control anti hop bars. I'm running low 11's with no problems.....
    Now I have snapped axles and c-clips but that was when the rear was in stock form. I have been told that this rear setup the way it is that I can handle 700HP with no problem..... The only problem is will the floor boards.... I have to next weld on battle boxes to prevent the torque from ripping the floor apart....
    any question on these rears, please feel free to ask....
    1987 Cougar XR7 308 S/C
    Trick Flow Heads/S-Trim/42lb. Inj./Stg. 1 cam/4.10 Detroit Locker,Yukon Axles,T/A Rear End Housing,CHE Upper Control Arms,Chucks Poly motor mounts,
    Working A/C -- BBK Shorties/ H-Pipe/ Flowmasters/ Eibach Springs/SSM lift bars/ Max Motorsports subframe connectors/3300 stall convert/ etc....... list keeps going
    Lots and Lots of Parts to make you go FAST !!
    2008 Mustang GT - - Dark candy Apple Red
    Roush Louvers;18" Polished Bullit Rim;3.55 Posi;Hood Scoop;Pypes Exhaust
  6. #46
    Join Date
    Oct 2004
    Location
    Farmingdale, NY
    Posts
    9,092
    Feedback Score
    18 (100%)
    Default
    Yukon Axles
    I'm hearing REAL good things about Yukon products. The whine fro the Richmonds I threw in ('cause NOBODY had a set of FRPP 3.45's) @ 40 MPH is ever so slight, but it's enough that I want to swap them out....and yes they were installed correctly. The whine has been constant. Hasn't changed a bit.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
