Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
Thread: 7.5 vs 8.8
  1. #21
    Join Date
    Oct 2004
    Location
    Dunnville Ontario Canada
    Posts
    2,993
    Feedback Score
    1 (100%)
    Default
    In my experience, (I have GRENADED 4, 7.5" rears. one behind a 4.2L V8, and the others behind stock 5.0L's) It is the spider gears and the main carrier caps that let go. The last one I wrecked, I never did find all the pieces of the spider gears, and the caps both broke into 3 seperate pieces EACH. spend your money wisely. go 8.8" or waste your money and blow up a 7.5
    And the weight isn't that much more, maybe 20lbs.
  2. #22
    Join Date
    Oct 2004
    Location
    NE Ohio
    Posts
    6,191
    Feedback Score
    6 (100%)
    Default
    A properly built 7.5" rear will withstand quite a bit of abuse. The key is to get a rear end girdle cover (yes, they exist for 7.5" rears) and a good locking center section. After that, thrash away.
    So the weight thing...let me explain. I pulled the 80 lb. difference info from two different sources: my mechanic, and a magazine article. The mag--meh, not so sure about them as they've had errors in the past, but still, it felt correct to me. My mechanic--very trustworthy as he's the driveline specialist at the Ford dealership where he works. I think since he works on FWD and RWD vehicles, Focuses to F-350's, and also races Mustangs on the weekends, he can give a very good idea of weight differences between components.
    A standard Cougar/T-Bird 7.5" open rear end with 2.73 gears and 9" drum brakes is the baseline. The top-of-the-line, I suppose, would be a 1987-88 Turbo Coupe 8.8" locking rear end with 3.73 gears, 10" discs and quad shock brackets. Fully loaded with brakes and gear oil, the difference in weight between those two rear ends is quite dramatic. Is it exactly 80 lbs.? Never said that. Is it realistically more like 40-50 lbs.? Possibly. I do know that I can carry a basic, loaded 7.5" rear around by myself but need help with a loaded 8.8" rear. And I'm not that big of a pu$$y...I can lift some fairly serious weight around. So it the real difference between 7.5" and 8.8" rear ends a mere 10 lbs.? I don't think so. Bare, possibly. Not fully loaded. No way. I think it's funny how everyone jumps to conclusions about "only a 10 lb. difference" when there aren't even any brakes attached. Isn't that how you, um, you know...USE a rear end in the real world?!
    In the near future I will have the opportunity to weigh both, fully loaded to fully loaded, and will report actual numbers when I get them. I also have separate components (gears, center sections, 9" and 10" drums, etc.) that I'll throw into the mix, just for solid numbers. That should help smooth things out.
  3. #23
    Join Date
    Apr 2005
    Location
    Ozark Mo
    Posts
    2,540
    Feedback Score
    1 (100%)
    Default
    I know of several 7.5 that have been used and abused that are still in working order.
  4. #24
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,506
    Feedback Score
    14 (100%)
    Default
    buddy of mine had a Dominator Mustang that had a 7.5 under it-withstood a bunch of high-13 second 1/4 runs...
    I pulled my TC's 8.8 just last week, and I will say that there IS more than 10 pounds of weight difference between it and a 7.5, and this was the complete rear, even the quad shocks
    I could barely lift it into the back of my truck, and I ain't no wimp!
    I can pack around a 7.5 by myself, but I sure as hell can't an 8.8..
    '84 and '87 Mustangs
    '98 Explorer
    FORD forever!
  5. #25
    Join Date
    Oct 2004
    Location
    Posts
    2,993
    Feedback Score
    1 (100%)
    Default
    The mustang 8.8" dont seem to be that much heavier the the 7.5"ers I will be pulling the differential out of my '88 stang this week and I will weigh it when I do so we have numbers on those as well.
  6. #26
    Join Date
    Dec 2006
    Location
    Fairfield, Ca
    Posts
    2,074
    Feedback Score
    2 (100%)
    Default
    I believe that the 8.8 axle tubes are only marginally larger as well. I changed the 7.5 trac-loc in my 86' for a 90' Lincoln 8.8 trac-loc w/rear discs and didn't notice much of a weight difference with the exception that I had left in the stock gears. BIG mistake!! I have since pulled the 8.8 and swapped in a 03' Cobra IRS. Now that does weigh 80# more than even the 8.8 live axle. But the trade off is worth it for me as I too will be autocross/road racing my car
    86' T/C 4.6L DOHC
    16' Chebby Cruze 1.4L Turbo
    “Heavy Metal Mistress”
  7. #27
    Join Date
    Oct 2004
    Location
    Indpls, IN
    Posts
    8,133
    Feedback Score
    34 (100%)
    Default
    The axle tubes on the 7.5 are 2.75" and on the 8.8 they are 3.00"
    Long live the 4-eyes! - '83 Tbird Turbo
  8. #28
    Join Date
    Jan 2006
    Location
    Warren. Rhode Island
    Posts
    4,832
    Feedback Score
    6 (100%)
    Default
    so rangers come with a 7.5? would a tc rear bolt in the ranger, cause if so ill have a posi unit to go with the 2.3t swap once i find a decent ranger.
    Shes black on black, fully loaded, with headers, 180 tstat, e fan, straight exhaust into a cherry bomb vortex muffler, full tune up, ported intake and T/B, MSD coil, and round aircleaner.
    my $300 beater
  9. #29
    Join Date
    Oct 2004
    Location
    Middle Sackville, NS, CANADA
    Posts
    9,845
    Feedback Score
    6 (100%)
    Default
    Some Rangers came with 7.5's some came with 8.8's. TC rears will not bolt into a Ranger - the Ranger has leaf springs (and brackets necessary to install them), while the TC rear is setup for four link/coil spring (again, with brackets to install 'em)
    1988 5.0 Thunderbird SOLD SEPT 11 2010: TC front clip/hood ♣ Body & paint completed Oct 2007 ♣ 3.55 TC rear end and front brakes ♣ TC interior ♣ CHE rear control arms (adjustable lowers) ♣ 2001 Bullitt springs ♣ Energy suspension poly busings ♣ Kenne Brown subframe connectors ♣ CWE engine mounts ♣ Thundercat sequential turn signals ♣ Explorer overhead console (temp/compass display) ♣ 2.25" off-road dual exhaust ♣ T-5 transmission swap completed Jan 2009 ♣
  10. #30
    Join Date
    Jan 2006
    Location
    Posts
    4,832
    Feedback Score
    6 (100%)
    Default
    damn, ill find a way to make it work, thats one thing im good at, making things into stuff its not ment to be, like a roll cage into a go cart intake and exhaust lol
    my $300 beater
Posting Permissions
  • You may not post replies
  • You may not edit your posts
