Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 46
Thread: 7.5 vs 8.8
  1. #11
    Join Date
    Oct 2004
    Location
    Knoxville, TN
    Posts
    3,643
    Feedback Score
    13 (100%)
    Default
    Woo-hoo I found it.
    http://corner-carvers.com/forums/sho...7.5+difference
    Sticky this B!
  2. #12
    Join Date
    Aug 2005
    Location
    Lebanon, Ohio
    Posts
    974
    Feedback Score
    2 (100%)
    Default
    Nice job thunder. You guys had me wonderin' too.
  3. #13
    Join Date
    Oct 2004
    Location
    Middle Sackville, NS, CANADA
    Posts
    9,845
    Feedback Score
    6 (100%)
    Default
    Nice find. I deem it stickyworthy
    1988 5.0 Thunderbird SOLD SEPT 11 2010: TC front clip/hood ♣ Body & paint completed Oct 2007 ♣ 3.55 TC rear end and front brakes ♣ TC interior ♣ CHE rear control arms (adjustable lowers) ♣ 2001 Bullitt springs ♣ Energy suspension poly busings ♣ Kenne Brown subframe connectors ♣ CWE engine mounts ♣ Thundercat sequential turn signals ♣ Explorer overhead console (temp/compass display) ♣ 2.25" off-road dual exhaust ♣ T-5 transmission swap completed Jan 2009 ♣
  4. #14
    Join Date
    Oct 2004
    Location
    Huntsville, AL
    Posts
    2,108
    Feedback Score
    2 (100%)
    Default
    Quote Originally Posted by darkthunder
    There was a thread about the weight difference a while back.
    Yes, too bad one can't find it via the search.
    http://www.foxtbirdcougarforums.com/...7&postcount=18
  5. #15
    Join Date
    Jan 2005
    Location
    Groveport, Ohio
    Posts
    1,104
    Feedback Score
    5 (100%)
    Default
    If you wanted True Posi just weld up the spider gears in your 7.5... that way you don't have to take a chance on getting the backlash perfect because you can weld it up with the axle still in one piece. I could never put in a carrier assembly without it later ripping to shreads. I tried carbon paper and lip stick to make sure the tolerances were correct but no matter what the 5 times i changed the gears they all went to crap!
    84 TC 302 -5.0L/t5/7.5 locking rear and a 3.45 gear, Edelbrock Intake, Aluminum Heads, Edlebrock 65mm Throttlebody, Edlebrock Cam, 24lb injectors & MAS Air Sensor calibrated via chip, BBK headers, Catback H pipe, Magnaflow mufflers
    Project Thread with pics
  6. #16
    Join Date
    Jun 2005
    Location
    Maine
    Posts
    576
    Feedback Score
    4 (100%)
    Default
    so WTH actually goes in the 7.5? alot of them sound like bad setup, or maybe defective gears...or is the carrier walking?
  7. #17
    Join Date
    Oct 2004
    Location
    Posts
    9,845
    Feedback Score
    6 (100%)
    Default
    Quote Originally Posted by blu84302
    That's a fine solution for a drag-only car, though if you ever plan on deviating from a straight line you might wanna second think it. It's called a differential for a reason - it's designed to allow the two wheels to travel at different speeds while turning. Welding up the spider gears creates a "spool", eliminating differential action and making cornering dangerous.
    BTW, if you REALLY want "True Posi" your only option is to install a GM rear end. "Posi Trac" is simply GM's brand name for the same setup Ford has (Ford calls it "Traction lock"), and the actual method of "Limited slip" (which is what all Posi and Trac-lock rears are) can vary even within the manufacturer - anything from the simple clutches like our rears have, to cones (Chrysler), to a mechanical ratcheting locker (GM Trucks), to an electronic locker (Toyota TRD package) and many others.
  8. #18
    Join Date
    Oct 2004
    Location
    NE Ohio
    Posts
    3,702
    Feedback Score
    3 (100%)
    Default
    I've lifted both a 7.5 and an 8.8 and I can say that 80lb figure does seem a little high. I only repeated it because I've heard it from 2 or 3 reliable sources.
  9. #19
    Join Date
    Aug 2005
    Location
    Lebanon, Ohio
    Posts
    974
    Feedback Score
    2 (100%)
    Default
    What kind of value would you guys put on the 8.8, if you had one to sell, or were looking to buy one, like from an 87' or 88' TC?
  10. #20
    Chris1987LX's Avatar
    Chris1987LX is offline "Thank God for the decent people." Hunter S. Thompson 1971
    Join Date
    Oct 2004
    Location
    The City of Brotherly Love, PA
    Posts
    1,149
    Feedback Score
    0
    Default
    Maybe this fits here, maybe it doesn't, but I had 3.73's installed in my 7.5 and found it to provide plenty of off-the-line go. I never abuse the car or mash the throttle, so hopefully I never have to worry about the rear failing.
    Chris
Posting Permissions
  • You may not post replies
  • You may not edit your posts
