Results 1 to 4 of 4
Thread: 87 7.5inch to 8.8 inch swap
  1. #1
    Join Date
    Aug 2018
    Location
    South Carolina
    Posts
    4
    Feedback Score
    0
    Default 87 7.5inch to 8.8 inch swap
    I want to swap the axle assembly on my 87 5.0 tbird from a 7.5 to an 8.8.
    i keep reading about people changing axles themselves so they can get a 5 lug pattern, but
    i want to change mine completely to a 8.8 and was wondering if a sn95 axle assembly bolts in or
    is there any mods that need to be done.
    i know the brakes will be different.
  2. #2
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,842
    Feedback Score
    17 (100%)
    Default
    SN95 8.8 bolts right in. You'll have to change the brake hose and parking brake cables but that should be it.
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  3. #3
    Join Date
    Aug 2018
    Location
    South Carolina
    Posts
    4
    Feedback Score
    0
    Default
    Thanks!!
  4. #4
    Join Date
    Oct 2004
    Location
    Indpls, IN
    Posts
    8,154
    Feedback Score
    34 (100%)
    Default
    As seen in the stick thread at the top of this section
    POST
    See the spreadsheet for axle width info. Not all "SN-95" read ends are the same.
    Long live the 4-eyes! - '83 Tbird Turbo
Posting Permissions
  • You may not post replies
  • You may not edit your posts
