Results 1 to 7 of 7
Thread: rear end
  1. #1
    Join Date
    Oct 2018
    Location
    NC
    Posts
    8
    Feedback Score
    0
    Default rear end
    curious if i get a rear end out of a 94-98 mustang 8.8 will 15 inch rim fit them 88 bird sport
  2. #2
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,375
    Feedback Score
    4 (100%)
    Default
    As long as you have the V6/GT rear brakes they should clear as the V6 SN95 cars did come with 15" wheels from the factory. I say this cautiously due to some aftermarket wheels have really thick "spokes" and can interfere with calipers (this is on all cars) but this is usually when someone is trying to pack a large brake package in a small wheel.
  3. #3
    Join Date
    Oct 2018
    Location
    NC
    Posts
    8
    Feedback Score
    0
    Default
    the v6 came with 7.5 correct or did some come with 8.8?
  4. #4
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,501
    Feedback Score
    14 (100%)
    Default
    7.5, but the axles, brakes, and everything will swap between the two, less the ring/pinion..no idea if bearings and seals interchange, been awhile, can't remember.
    '84 and '87 Mustangs
    '98 Explorer
    FORD forever!
  5. #5
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,375
    Feedback Score
    4 (100%)
    Default
    Same axle bearing and seal which makes some sense as the axles are the same so it means the axle tubes are the same or at least I would think they are. Differential bearings and races are different but that too makes sense as the ring gear and pinion are different sizes.
  6. #6
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,501
    Feedback Score
    14 (100%)
    Default
    Well, I knew they'd be the same dia, wasn't sure if the 8.8 may have had a wider bearing. Makes sense though, what you said.
    '98 Explorer
    FORD forever!
  7. #7
    Join Date
    Oct 2018
    Location
    NC
    Posts
    8
    Feedback Score
    0
    Default
    thank u
Posting Permissions
  • You may not post replies
  • You may not edit your posts
