Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Rear End Noises
  1. #11
    Join Date
    Dec 2007
    Location
    ONTARIO CANADA
    Posts
    509
    Feedback Score
    0
    Default
    Wow! There must have been a full moon when I went through the same thing. First I checked backlash. Was at. 012 so I tightened it to. 008. No difference. Replaced the spider gears and cross shaft. No difference. Looked closer and found the poly bushing on the upper arm was shot. I had boxed the uppers and installed poly bushing which I know now that doesn't work on a street car. Removed the plates I used to box the uppers and replaced the bushings. Still clunking.....WTF. I'm now at my wits end. Grabed the driveshaft and gave it a twist. Seemed a lot more than. 008. Pulled the cover AGAIN! Everything looked fine. Checked backlash again and it was all over the board at different spots. Looked closer. Found the problem. Friggin ring gear bolts were finger tight! Years ago when I didn't trust myself to do a gear change, I had a reputable shop do it. Lesson learned.
    84 COUGAR/88HO, 1.7RRs, performer RPM,700DP, equal length shorties, stainless EXH ,T-5,Hurst pro-billet, KC clutch, 8.8/ 4.10s, line-lok, bla ,bla, bla.
    71 COMET/289,351w heads, 12.5 TRWs, 750DP, Liberty TL, 9"/6.00s, 11.9x @112 , bla,bla,bla.
    Never shoot your mouth off, unless your brain is loaded! ....I may get older, but I'll never grow up!....If you're not laughing, you're not living!
  2. #12
    Join Date
    Oct 2017
    Location
    Michigan
    Posts
    31
    Feedback Score
    0
    Default
    Rear shocks are brand new.
  3. #13
    Join Date
    Oct 2017
    Location
    Michigan
    Posts
    31
    Feedback Score
    0
    Default
    I had a known rear end shop do mine, but sounds like I'm going to be taking the cover off and checking it out myself. I've heard off shops not having things properly tightened or torqued... I guess that's what I'm checking next. Thanks for the help! I'll let you know if it works out.
  4. #14
    Join Date
    Sep 2018
    Location
    Arizona
    Posts
    38
    Feedback Score
    0
    Default
    If they didn't put fresh lock tight on the ring gear bolts they may have come loose. Usually doesn't happen but sometimes small things like that get over looked in high volume shops just something to look at.
  5. #15
    Join Date
    Oct 2017
    Location
    Michigan
    Posts
    31
    Feedback Score
    0
    Default
    Yeah I will have to see, I'm interested to see what I find when I pop that cover off
  6. #16
    Join Date
    Oct 2017
    Location
    Michigan
    Posts
    31
    Feedback Score
    0
    Default
    Nothing I can tell that is wrong with the rear end itself, I'm thinking it has to be bushings or suspension, something along those lines. It'll be a while before I can figure that stuff out, this winter at some point. Thanks for all the help
  7. #17
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,375
    Feedback Score
    4 (100%)
    Default
    What did the 8.8 come out of? Does it have disc brakes?
  8. #18
    Join Date
    Oct 2017
    Location
    Michigan
    Posts
    31
    Feedback Score
    0
    Default
    It came out of an 88 TC, with disc brakes
  9. #19
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,375
    Feedback Score
    4 (100%)
    Default
    Check you brakes and make sure you assembled them correctly ie the caliper not moving and clunking around. Did the shop put new axle bearings in? These would be the ones in the outer axle tube not the ones holding the carrier in the rear end.
  10. #20
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,375
    Feedback Score
    4 (100%)
    Default
    Any update on this???
Posting Permissions
  • You may not post replies
  • You may not edit your posts
