Results 1 to 7 of 7
Thread: Which steering rack?.
  1. #1
    Join Date
    Mar 2015
    Location
    braintree ye olde england
    Posts
    132
    Feedback Score
    0
    Default Which steering rack?.
    3.8 cougar.just had my mot and failed on excessive play in the rack looked at rock auto but don't know which is correct . one/two piece mounting bush and with/without performance suspension what am I looking for?.
  2. #2
    Join Date
    Oct 2004
    Location
    Indpls, IN
    Posts
    8,110
    Feedback Score
    34 (100%)
    Default
    Year of car? Trim level?
    What is the diameter of your steering rack mounting bolts? The larger ones (M16 - ish) are the 1-piece bush. The smaller ones (M12's, I think) are the 2-piece. They also have a longer sleeve that goes into the K-member, that the others do not. Either bushing type will fit in the rack.
    Some folks retrofit the later (2-piece) bushing/sleeves for the 1-piece set-up. You can get poly bushings for either, but the 2-piece are more common.
    Unless your car is a turbo or an XR-7, it probably doesn't have the Sport suspension. Read up HERE ON COOLCATS for more info.
    Long live the 4-eyes! - '83 Tbird Turbo
  3. #3
    Join Date
    Mar 2015
    Location
    Posts
    132
    Feedback Score
    0
    Default
    It's an 86 just standard ,measured the mounting bolts got 12mm so 2 piece it is . going to drain and clean before refilling but can't find the amount of fluid I require to refill?.
  4. #4
    Join Date
    Aug 2014
    Location
    camdenton, mo
    Posts
    254
    Feedback Score
    1 (100%)
    Default
    Go with the performance rack, and just fill until shes full.
  5. #5
    Join Date
    Mar 2015
    Location
    Posts
    132
    Feedback Score
    0
    Default
    Ok got replacement rack already to fit came with new bushes and a pack of seals two same sized small rubber o-rings approx id 7.5mm 11.5mm od and two teflon seals different sized 11mm id 13.5 od & 13mm id 15mm od didn't find any seals on the pipe joins when I removed only PTFE tape on the threads also Manual doesn't mention anything about seals are these needed?.
  6. #6
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,801
    Feedback Score
    17 (100%)
    Default
    The teflon seals should be used where the hoses mount to the steering rack.
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  7. #7
    Join Date
    Mar 2015
    Location
    Posts
    132
    Feedback Score
    0
    Default
    Ok thanks also found the two small o-rings fit on the pipe under the nuts.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
