Page 8 of 12 FirstFirst ... 456789101112 LastLast
Results 71 to 80 of 119
Thread: Claude puts his car back together.
  1. #71
    Join Date
    Jan 2005
    Location
    Lancaster, OHIO
    Posts
    4,987
    Feedback Score
    3 (100%)
    Default
    Went to the farm today and went scrounging in parts stashes. Came out with a dual seat harness and trim plate, a power antenna minus the switch and a box of 30lb and 24lb injectors and what is probably my 4th set of SE badges. Even found my Chuck shock brackets!
    Join Date
    Jan 2005
    Location
    Lancaster, OHIO
    Posts
    4,987
    Feedback Score
    3 (100%)
    Default
    I found the 65mm Explorer tb I never installed and a very rusty 5 lug conversion.
    Join Date
    Oct 2004
    Location
    Pasadena, MD
    Posts
    7,521
    Feedback Score
    7 (100%)
    Default
  4. #74
    Join Date
    Mar 2018
    Location
    Connecticut
    Posts
    50
    Feedback Score
    0
    Default
    I had real good luck with Evapo-Rust. I did before and after pictures, but that was before Photobucket went to the dark side.
    If you want to peruse the pictures are here: http://i233.photobucket.com/albums/e...evapo_rust.jpg
    Edit: make sure you paint or zinc plate the parts after removing the rust with Evapo Rust otherwise they rust up very quickly being exposed.
  5. #75
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,801
    Feedback Score
    17 (100%)
    Default
    You've got a lot of parts stashed away.
    Those 24lb injectors should be fine with GT40 heads. Save the 30lb injectors. If you ever go with better flowing aluminum heads you'll need them (my car did).
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  6. #76
    Join Date
    Jan 2005
    Location
    Lancaster, OHIO
    Posts
    4,987
    Feedback Score
    3 (100%)
    Default
    Quote Originally Posted by thunderjet302 View Post
    There is only 6 30lb injectors. I don’t know if I will ever go the aluminum head route. Probably switch engine platforms before that.
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,801
    Feedback Score
    17 (100%)
    Default
    30lb injectors are probably from a Thunderbird SC, since you only have 6.
    I've thought about Coyote swaps. By the time I get all required parts/a new transmission I might as well go Dart 363 and be done with it.
  8. #78
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,502
    Feedback Score
    14 (100%)
    Default
    But, that 363 is pretty much at a ceiling, whereas the Coyote design isn't even close to it's peak yet..
    If it weren't a question of money, my next project would be a Coyote. Or even a 32v...
    '84 and '87 Mustangs
    '98 Explorer
    FORD forever!
  9. #79
    Join Date
    Oct 2004
    Location
    Pasadena, MD
    Posts
    7,521
    Feedback Score
    7 (100%)
    Default
    LSx and be done with it.
  10. #80
    Join Date
    Jan 2005
    Location
    Lancaster, OHIO
    Posts
    4,987
    Feedback Score
    3 (100%)
    Default
    2JZ brah
Posting Permissions
  • You may not post replies
  • You may not edit your posts
