Results 1 to 6 of 6
Thread: C4/FMX Question
  1. #1
    Join Date
    Feb 2005
    Posts
    460
    Feedback Score
    0
    Default C4/FMX Question
    Hey all,
    Been "years" since I've been here, so please excuse my absence. I hopefully am about to purchase an 86 Cougar with what sounds like a burnt-up C5 trans. I will not be financially able to afford a rebuild on the C5. I have found both C4's and FMX's in my area for pretty reasonable prices. I haven't found any C5's. Oh, and it will be going behind the 3.8. My question is, are either of those a good candidate to swap, if I'm on a tight budget? I've read that the C5 is basically a C4 with a lockup converter. Would I need to swap the flywheel? I don't believe that Ford ever put a C4 behind the 3.8 from the factory, did they? Anyway, I appreciate any advice. Glad to hopefully have a reason to return to the site. Take care.
  2. #2
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,283
    Feedback Score
    2 (100%)
    Default
    Do a 3.8 t-5 from a 94-98 mustang.
    Pretty much bolts in. Swap pedals, add a flywheel/clutch and buy the trans for $150 at a u pull it yard
    Quote Originally Posted by jcassity
  3. #3
    Join Date
    Aug 2014
    Location
    camdenton, mo
    Posts
    260
    Feedback Score
    1 (100%)
    Default
    What was the total setup to use that v6 t5?
  4. #4
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,283
    Feedback Score
    2 (100%)
    Default
    Use 94 up mustang parts. That's pretty much it. There's a sticky here somewhere with a full write up.
    The driveshaft will be too short.
  5. #5
    Join Date
    Mar 2018
    Location
    Connecticut
    Posts
    56
    Feedback Score
    0
    Default
    IMO if deciding between a C4 and FMX, I would choose the C4. Plenty of shift and rebuild kits available .
  6. #6
    Join Date
    Feb 2005
    Posts
    460
    Feedback Score
    0
    Default
    I was actually to find a C5 somewhat close, which I assume is in good running condition (the CL seller didn't expressly state what condition it was in) for $150. I'm not going the hotrod route with this car anyway (which I still haven't purchased but hope I'm close), so I never plan to modify the trans for that 120HP V6. The C5 should be a plug-n-play install, shouldn't it. Does it matter what year or car that the C5 came from? That's probably the route I'll take if I get the car and the transmission seller still has the C5 when I get ready. Just out of curiosity, would the C4 have gone right in the place of the C5 without any issues? Need to swap flywheel? Bolt patterns line up? Thanks again.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
