Page 3 of 10 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 92
Thread: LED Bulb Conversion (Whole Car)
  1. #21
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,826
    Feedback Score
    17 (100%)
    Default
    What turn signal flasher did you end up using when you changed over to LEDs?
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  2. #22
    Join Date
    Oct 2004
    Location
    NE Ohio
    Posts
    6,191
    Feedback Score
    6 (100%)
    Default
    Have to use an electronic flasher with the ground wire. It won't work ungrounded. Fortunately there are plenty of places around the flasher to make a good, permanent ground.
    Also, it seems that you can use incandescent bulbs with the electronic flasher with no penalty.
    Speaking of...turn signal demo, full LED conversion:
    http://www.coolcats.net/ximages/84leds/84ts.mp4
    The lights aren't really that pink. Difficult to capture these on a camera but you can get the basic idea.
    This is what it looks like when you have a mix of bulbs...incandescent on the left, LED on the right:
    http://www.coolcats.net/ximages/84leds/84ts_old.mp4
  3. #23
    Join Date
    Mar 2018
    Location
    Connecticut
    Posts
    55
    Feedback Score
    0
    Default
    Looks really good with the conversion.
    Have you changed the headlights over yet and if so how do you like them?
    Most of the conversions I have seen so far they didn't have the dash dimmable which is a no go for me.
    And there is my second post after lurking here a while.
  4. #24
    Join Date
    Oct 2004
    Location
    NE Ohio
    Posts
    6,191
    Feedback Score
    6 (100%)
    Default
    There is an LED headlamp in this photo:
    And in this photo:
    Difficult to tell, no?
    ...but you can definitely tell here:
    They still need aimed so I haven't gotten photos of the full headlamp set yet. I'll get those when I can. So far so good, though. This particular brand uses such a stock-looking assembly that it's practically impossible to know it's LED, even if you're right up on it.
  5. #25
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,826
    Feedback Score
    17 (100%)
    Default
    Quote Originally Posted by EricCoolCats View Post
    I have Thunderchicken's old sequential turn signal box. I wonder if the LEDs would work with it.
    I'm not totally fond of the LED headlamps. Too blue for my taste.
  6. #26
    Join Date
    Oct 2004
    Location
    NE Ohio
    Posts
    6,191
    Feedback Score
    6 (100%)
    Default
    You might get lucky with that sequential unit and just replace the flasher with the electronic one. If it were me, I'd definitely try it.
    My headlights are actually bright white with a bluish hint but they don't photograph like that. I really wanted something a little yellower. In the future there might be replacement bulbs in the ~4500K range and I'll swap over to them instead, but for now these are good for my tastes.
    I'd think for your situation, there would be plenty of color ranges available for those bulbs...
  7. #27
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,826
    Feedback Score
    17 (100%)
    Default
    I've yet to find an LED headlamp bulb that I think is close enough to the stock light.
    I've got that whole "it looks stock with the hood shut" vibe to protect .
  8. #28
    Join Date
    May 2016
    Location
    Lancaster, PA
    Posts
    229
    Feedback Score
    1 (100%)
    Default
    Eric - what did you have to do as far as the wiring goes for the headlights? I've been considering this, but I'm leery of hacking into the harness.
  9. #29
    Join Date
    Oct 2004
    Location
    NE Ohio
    Posts
    6,191
    Feedback Score
    6 (100%)
    Default
    The bulbs in mine were pre-wired for stock pigtails, so I needed to do nothing. Some of the aftermarket setups use an H4-style wiring style, which requires some type of adapter or harness to work in our cars. What I found is that it's buyer beware...read the descriptions to make sure they're compatible with the stock wiring and, if not, that they include an adapter harness. Most of the quality ones do, though.
  10. #30
    Join Date
    Dec 2006
    Location
    Fairfield, Ca
    Posts
    2,074
    Feedback Score
    2 (100%)
    Default
    So Eric, where did you get those headlights?? Those are exactly like what I've been looking for.
    86' T/C 4.6L DOHC
    16' Chebby Cruze 1.4L Turbo
    “Heavy Metal Mistress”
Posting Permissions
  • You may not post replies
  • You may not edit your posts
