Results 1 to 7 of 7
Thread: Engine timing education needed....
  1. #1
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,528
    Feedback Score
    135 (100%)
    Default Engine timing education needed....
    I'll try to word this right......I feel like an idiot already even asking......
    Since I installed the new distributor a couple of weeks ago, the car has been acting a little weak, not right. I thought I had set the timing at 14 degrees.
    I have a new timing light I got a few months ago and was using it. it has the dial on the back, and I lost the instructions...never used one like this in my life.
    I removed the spout, started the car and checked the timing. It should 10 degrees. I set the dial on the timing light at 0 and set the timing to 14, car wasn't right......so, I set the dial to 14 degrees, and the timing on the balancer at 14....car is running stronger than it ever has so far. I guess my question is, what is the proper way to use this light with the dial? Did I use it right at all? My old light was simply aim and time. No digital panel, no dial.
    '88 Sport--T-5,HURST shifter,Trick Flow R intake,Ed Curtis cam,Trick Flow heads,Scorpion rockers,75mm Accufab t-body,3G,mini starter,Taurus fan,BBK long tube headers,O/R H-Pipe, Flowamaster Super 44's, deep and deeper Cobra R wheels, Mass Air and 24's,8.8 with 3.73's,140 mph speedo,Mach 1 chin spoiler,SN-95 springs,CHE control arms,aluminum drive shaft and a lot more..
  2. #2
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,501
    Feedback Score
    15 (100%)
    Default
    vinnie,
    the knob to me would be compatible with a carb to tune for dwell.
  3. #3
    Join Date
    May 2005
    Location
    Newmarket, ON, Canada
    Posts
    169
    Feedback Score
    0
    Default
    You have the right idea except the dial is for advance. You can either set it to 14 then line up zero on the balancer or leave the dial at zero and use it like your old light.
    John
  4. #4
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,283
    Feedback Score
    2 (100%)
    Default
    I did the same thing. I had a good old school timing light. The bulb finally burned out, couldn't order a replacement so bought s new one. Same thing happened to me, and I felt like an idiot also.
    Quote Originally Posted by jcassity
  5. #5
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,528
    Feedback Score
    135 (100%)
    Default
    That answered my questions. Thanks a lot!!!
    I'm going to experiment. I will set the light at 14, then move the timing (with the distributor) to zero......if I read that correctly above, then try it the other way (set the dial at zero and set the balancer at 14). I appreciate you guys.
  6. #6
    Join Date
    Feb 2009
    Location
    Belleview, FL
    Posts
    2,847
    Feedback Score
    8 (100%)
    Default
    I think you should revise your thread title to "Engine timing light education needed" lol
    --Steve
    1988 Cougar V6
    2011 Mustang 3.7L
  7. #7
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,528
    Feedback Score
    135 (100%)
    Default
    Good point. LOL
Posting Permissions
  • You may not post replies
  • You may not edit your posts
