Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
Thread: O2 sensor bung
  1. #11
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,501
    Feedback Score
    15 (100%)
  2. #12
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,850
    Feedback Score
    7 (100%)
    Default
    His sensor is still 4 wires, whether the signal ground goes to the back of the head (orange wire) or all the way to the EEC. Grounding to the the engine IS noisier, but with high quality grounds and ordinary noise suppression methods, it should be good enough for his purposes. The point I was making, however, is that his 87 doesn't ground the sensor through the threads, and it is heated.
    1988 Thunderbird 5.0
    GT40P, TFS-1, KB domes, 30#, MAF conversion, Explorer GT40 Upper/Lower, Smog delete, Wide Ratio AOD Mod, Unlocked Speedo, 3G Charging System Upgrade, Hi-Torque Mini Starter, 3.73 LSD, BBK 1 5/8 unequal headers, H-Pipe.
    88 Thunderbird/Cougar EVTM
    (Thanks to Trinom for hosting)
  3. #13
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,501
    Feedback Score
    15 (100%)
    Default
    LOL,, you arei right again,,, here i is that ground wire point........... which is under the braided cable i made... it is orange.
    i located my original braided flat ground lead so i removed this one i show and installed the original.
    Attached Images Attached Images
  4. #14
    Join Date
    Oct 2004
    Location
    Southern Maryland
    Posts
    2,662
    Feedback Score
    0
    Default
    87 3 wire O2 sensor:
  5. #15
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,850
    Feedback Score
    7 (100%)
    Default
    Well, shit. I guess I take it back.
  6. #16
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,501
    Feedback Score
    15 (100%)
    Default
    yeah,, thats what i was trying to say but since you brought up the technicality of the orange wire,,, that would make it a 4 wire thingy but they are actually 3wire.
  7. #17
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,501
    Feedback Score
    15 (100%)
    Default
    on 87 & 88 cars the orange wire is under the braided cable on the driver side which is attached at the fire wall just next the the accelerator cable.
    so the orange wire belongs on the fire wall, not the head.
    te braided cable is on the same spot on the fire wall and lands on the rear of the driver head.
    same point electrically but just sayin.....
  8. #18
    Join Date
    May 2005
    Location
    Newmarket, ON, Canada
    Posts
    169
    Feedback Score
    0
    Default
    Interesting...the tbird-cougar is different? I've always seen the mustangs either to the back of the head or the rear lower intake stud ( mine). The Turbocoupe has it on the turbo compressor housing. I've never seen it paired up with the braided cable to the firewall.
    John
  9. #19
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,850
    Feedback Score
    7 (100%)
    Default
    When I got my car, it was already a Mark VII HO swap. engine, trans, exhaust; which included the EEC and complete engine harness, so some things on my car don't conform to T-Bird/Cougar wiring books. My orange wire goes from the EEC to the back of the head, then from the back of the head to a splice and to each HEGO, and mine are 4 wire, as far as I can tell, not like T-bird/Cougar or Mustang. Or really even like Mark VII books. When I lost the HEGO sub harness during my last build, I had to build a new one from memory and that's how I built it.
  10. #20
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,826
    Feedback Score
    17 (100%)
    Default
    Quote Originally Posted by jcassity View Post
    My 88 is set up this way. I did add a ground wire from the ground point on the firewall to a stud on the back of the intake. Didn't seem to make any difference but it makes me feel better .
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
Posting Permissions
  • You may not post replies
  • You may not edit your posts
