Results 1 to 6 of 6
Thread: Dash board lights out
Hybrid View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Join Date
    Oct 2013
    Location
    indiana
    Posts
    16
    Feedback Score
    0
    Default Dash board lights out
    My dashboard lights went out in my car yesterday, but them came back on later. Then they went out again. I noticed that when they did work and I used the dimmer switch to turn on inside lights the dash went dark again, but came back on when i turned off interior lights with the dimmer switch. Does this sound like a bad headlight/dimmer switch? I did have a turn signal and headlight out, but i replaced them and this happened after. Any suggestions or advice, thanks!
  2. #2
    Join Date
    Sep 2006
    Location
    Olathe, Kansas
    Posts
    2,408
    Feedback Score
    3 (100%)
    Default
    First thing, what year car are you talking about? Analog or Digital dash?
    Mike
  3. #3
    Join Date
    Oct 2013
    Location
    indiana
    Posts
    16
    Feedback Score
    0
    Default
    1988 digital speedometer but analog guages forgot to add that.
  4. #4
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,792
    Feedback Score
    17 (100%)
    Default
    Check the wiring for the headlamp/dimmer switch. Sometimes they burn, causing weird issues, since the power for the lights runs through the switch. Also check the ignition switch, especially if any other weird electrical gremlins are present.
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  5. #5
    Join Date
    Oct 2013
    Location
    indiana
    Posts
    16
    Feedback Score
    0
    Default
    Quote Originally Posted by thunderjet302 View Post
    Thanks for the advice.
  6. #6
    Join Date
    Oct 2013
    Location
    indiana
    Posts
    16
    Feedback Score
    0
    Default
    I took it out and there was a bunch of blue/green powder residue underneath the switch. I blew that off and it seems to be working now, but still shuts off the panel when i turn the done light. What is that part specifically called that I would replace? When I have looked up the headlight switch it doesn’t look like the part that I saw.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
