Results 1 to 5 of 5
Thread: 86 turbo coupe side moulding
  1. #1
    Join Date
    Jan 2018
    Location
    Chesapeake VA
    Posts
    28
    Feedback Score
    0
    Default 86 turbo coupe side moulding
    when the original owner painted the car, he painted over (gloss black) the side mouldings then used red pinstripe tape to put the red accent back on....actually it didn't look too bad.
    Wondering if soda blasting will take off this paint and not harm the original rubber trim?
  2. #2
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,821
    Feedback Score
    17 (100%)
    Default
    Maybe? Depends on how it was painted.
    If you remove the molding do it carefully. You can bend the bejesus out of the aluminum backing and destroy the molding if you're not careful.
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  3. #3
    Join Date
    Feb 2012
    Location
    Monona, Iowa
    Posts
    477
    Feedback Score
    3 (100%)
    Default
    There are chemical paint strippers just for plastic parts. SEM 39913. I dislike using chemical paint strippers but they do work, sorta.
  4. #4
    Join Date
    Jan 2018
    Location
    Chesapeake VA
    Posts
    28
    Feedback Score
    0
    Default
    Ill try a small area, my soda guy recommended laquer thinner, will take the paint off, but flashes pretty quick so as not to damage plastic...sounds good??????
  5. #5
    Join Date
    Feb 2012
    Location
    Monona, Iowa
    Posts
    477
    Feedback Score
    3 (100%)
    Default
    Laquer thinner most likely wont take off cured paint unless it is was really cheap, won't hurt to try.
    Just last night I was working on my bumper covers and decided to try sand blasting the paint off in the hard to sand areas, did a small test spot and it worked fine. I used the suction blaster in my cabinet and kept the air pressure at 90 and was careful not to get to close. The paint and primer that were not factory came off pretty quick, the factory paint and primer took some time. Between the DA sander, blasting and some hand sanding I have at least 4 hours in getting the paint off the rear bumper.
    There is really no quick fix, takes time and elbow grease. Chemical stripper, sanding by hand or a DA on larger areas, or possibly try a blaster, those are about it. If you get them down to bare plastic make sure to use a plastic primer adhesion promoter on them first. Sanding on plastic tends to tear it up a little bit so you may want to spray them with primer surface with flex add and re-sand them before paint.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
