Page 2 of 7 FirstFirst 123456 ... LastLast
Results 11 to 20 of 61
Thread: Oil Leak - Ideas?
  1. #11
    Join Date
    Oct 2004
    Location
    East Coast Virginia
    Posts
    10,228
    Feedback Score
    0
    Default
    Ughh, ffin 4.6/5.4, glad I'm retired, don't have to mess with such tripe...
    I paid a friend to replace the POS plastic intake on my '98 Grand Marquis that busted at 63K mi, didn't want to do it myself(I'd already had intake for a couple months)...
    When I installed the 5.0 AOD into Bird I did it as a unit, without help, using cherry picker... Definitely touchy... When I pulled it back out I dropped transmission, apparently the old saying "balls shrink with age" applies...
    My other rides (that actually do run & drive)
    1969 Fairlane Cobra 428CJ 4-Speed << New 49th Birthday Picture
    1972 Comet GT - 306 C4
  2. #12
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,850
    Feedback Score
    7 (100%)
    Default
    That's a 4.2 with a manual. Just about as bad.
    1988 Thunderbird 5.0
    GT40P, TFS-1, KB domes, 30#, MAF conversion, Explorer GT40 Upper/Lower, Smog delete, Wide Ratio AOD Mod, Unlocked Speedo, 3G Charging System Upgrade, Hi-Torque Mini Starter, 3.73 LSD, BBK 1 5/8 unequal headers, H-Pipe.
    88 Thunderbird/Cougar EVTM
    (Thanks to Trinom for hosting)
  3. #13
    Join Date
    Oct 2004
    Location
    East Coast Virginia
    Posts
    10,228
    Feedback Score
    0
    Default
    Quote Originally Posted by TheFoeYouKnow View Post
    Oh yeah, my bad, should have taken a better look...
    Everything is buried but if nothing else, the three runner exhaust manifold gives it away...
  4. #14
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,850
    Feedback Score
    7 (100%)
    Default
    The hard part is getting that 10 spline input shaft to line up.
  5. #15
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,826
    Feedback Score
    17 (100%)
    Default
    Does the 4.2 eat head gaskets as fast as the 3.8?
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  6. #16
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,850
    Feedback Score
    7 (100%)
    Default
    Pictured is a Jasper reman. Head gasket failure, preceeding head failure, allowing coolant contamination of the oil, ending in extreme bottom end wear. She was knocking like a bill collector.
  7. #17
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,850
    Feedback Score
    7 (100%)
    Default
    Sorry for the threadjack, I'm all done.
  8. #18
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,826
    Feedback Score
    17 (100%)
    Default
    Quote Originally Posted by thunderjet302 View Post
    So the answer is yes.
    Sorry for hijacking.
  9. #19
    Join Date
    May 2015
    Location
    MI
    Posts
    103
    Feedback Score
    0
    Default engine removal
    Hey, does the steering coupler shaft need to be pulled in order to get this motor out??
  10. #20
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,850
    Feedback Score
    7 (100%)
    Default
    Shouldn't, but it may be helpful to take the exhaust manifold out on that side. You don't even have to do THAT, but if you were concerned about space, it would help you get the space you're looking for. Imagine creating a spherical "gap" around the engine (to the extent possible).
Posting Permissions
  • You may not post replies
  • You may not edit your posts
