Results 1 to 8 of 8
Thread: Tachometer issues
Hybrid View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Join Date
    Aug 2017
    Location
    Bellport,New York
    Posts
    4
    Feedback Score
    0
    Default Tachometer issues
    I'm new to the group and this is my first post.I'm having issues with the tach in my 1988 Thunderbird Sport 5.0 (analog gauges).I replaced the voltage regulator on my cluster and after that my tach barely moves.At 45mph instead of showing 1500rpm,its not even at 1000.I put the stock regulator back in and no difference even after resetting the computer.The TFI module is new as is the coil so they aren't the culprits.I figure its the wire going to the computer.The coil to cap wire itself is 3 years old (Ford 9mm Racing Wires)and the car runs alright otherwise for 219,000+ miles.I just dont feel like tearing into the computer,especially with no garage and freezing weather lol.If anyone has any idea what it could be,i would appreciate some input.I originally replaced the regulator because my oil gauge was always reading low and i had read an old regulator could give false readings.Because i know someone will ask why i tried changing it
  2. #2
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,850
    Feedback Score
    7 (100%)
    Default
    Make sure your connectors are seated tightly into the cluster.
    1988 Thunderbird 5.0
    GT40P, TFS-1, KB domes, 30#, MAF conversion, Explorer GT40 Upper/Lower, Smog delete, Wide Ratio AOD Mod, Unlocked Speedo, 3G Charging System Upgrade, Hi-Torque Mini Starter, 3.73 LSD, BBK 1 5/8 unequal headers, H-Pipe.
    88 Thunderbird/Cougar EVTM
    (Thanks to Trinom for hosting)
  3. #3
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,283
    Feedback Score
    2 (100%)
    Default
    At 45mph you should be about 1200rpms, 1500 rpms would be about 60mph highway.
    Quote Originally Posted by jcassity
  4. #4
    Join Date
    Oct 2004
    Location
    East Coast Virginia
    Posts
    10,228
    Feedback Score
    0
    Default
    Go back over your connections, snug the three nuts on back of cluster that make the connections to tach...
    As far as computer, has zero to do with tach operation...
    My other rides (that actually do run & drive)
    1969 Fairlane Cobra 428CJ 4-Speed << New 49th Birthday Picture
    1972 Comet GT - 306 C4
  5. #5
    Join Date
    Oct 2004
    Location
    Southern Maryland
    Posts
    2,662
    Feedback Score
    0
    Default
    The 88 EVTM doesn't show the analog tach for the 5.0 sport.
    The Turbo Coupe analog tach does not use the IVR (instrument voltage regulator) or, as Turbocoupe50 says, the computer.
    Turbo Coupe cluster connector C285 uses pins 1, 16 and 12 for the tach
    Pin 1 circuit #640 R/Y is power from fuse 16.
    Pin 16 circuit #11 DG/Y is from the Tach side of the coil.
    Pin 12 circuit #57 BK is ground.
    The Sport cluster connector has the same circuit numbers and color codes on pins 1, 16 and 12.
    My guess is it works the same as the Turbo Coupe.
    OOPS!!! I put the red box on pin 17, it should be on pin 16 for the Turbo Coupe connector.
    Attached Images Attached Images
  6. #6
    Join Date
    Oct 2004
    Location
    East Coast Virginia
    Posts
    10,228
    Feedback Score
    0
    Default
    Quote Originally Posted by softtouch View Post
    Yep, I have a '88 Sport tach in my original TC cluster...
    If fact only differences in the motor & Sport tach are one resistor and the faces...
    Note this is for '87 & '88, earlier Turbo Coupe tachs have entirely different circuitry...
  7. #7
    Join Date
    Aug 2017
    Location
    Bellport,New York
    Posts
    4
    Feedback Score
    0
    Default
    The only reason bring up the computer is because the yellow/green wire off the TFI runs to the relay off the computer.I had read elsewhere that if its making a bad connection (wire possibly exposed and grounding out)it can affect the rest of the electronics related to the ignition, which in turn sends the signal to the tachometer.
  8. #8
    Join Date
    Aug 2017
    Location
    Bellport,New York
    Posts
    4
    Feedback Score
    0
    Default
    I took the tach apart,cleaned everything up,and finally got it working properly
Posting Permissions
  • You may not post replies
  • You may not edit your posts
