Page 3 of 14 FirstFirst 123456713 ... LastLast
Results 21 to 30 of 137
Thread: Replacing Intake, throttle body- questions?
  1. #21
    Join Date
    Mar 2006
    Location
    Henderson, NV
    Posts
    212
    Feedback Score
    0
    Default
    The car is a real Turbo Coupe. If I remember the tag on the rear end showed 355's. I have heard they also came with 373's.
  2. #22
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,801
    Feedback Score
    17 (100%)
    Default
    Quote Originally Posted by tommym View Post
    If it was a factory 5 speed Turbo Coupe than it had 3.55s. What T5 do you have?
    If you had 3.73s I was going to suggest a little more aggressive intake, but with 3.55s and a T5 the GT40 intake should work great.
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  3. #23
    Join Date
    Oct 2004
    Location
    East Coast Virginia
    Posts
    10,228
    Feedback Score
    0
    Default
    For the '87 & '88, 5-spd 3.55, auto 3.73...
    Earlier model TC all had 7.5" 3.45 reguardless of transmission...
    My other rides (that actually do run & drive)
    1969 Fairlane Cobra 428CJ 4-Speed << New 49th Birthday Picture
    1972 Comet GT - 306 C4
  4. #24
    Join Date
    Mar 2006
    Location
    Henderson, NV
    Posts
    212
    Feedback Score
    0
    Default
    The T-5 I have is- 1994 T5 5 Speed (ID #1352-246), (P/N F4ZR-7003-DA)
    It has a 335 1st gear and a .68 5th gear. At 70 I'm hitting 2000.
  5. #25
    Join Date
    Mar 2006
    Location
    Henderson, NV
    Posts
    212
    Feedback Score
    0
    Default
    Making some progress getting parts. The heads will be Trick Flow 170, 61cc, Trick Flow 1.6, Haven't decided on the cam yet. Any suggestions?
  6. #26
    Join Date
    Mar 2006
    Location
    Henderson, NV
    Posts
    212
    Feedback Score
    0
    Default
    Here's the valve covers I plan on using. I'm not really into a lot of chrome but these looked good.
  7. #27
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,801
    Feedback Score
    17 (100%)
    Default
    For something off the shelf the Comp XE264HR would go well. It should make power to 5500rpm and be very streetable.
  8. #28
    Join Date
    Mar 2006
    Location
    Henderson, NV
    Posts
    212
    Feedback Score
    0
    Default
    Thank you. That sounds good. I'm not building a race car just one that is fun to drive. My knowledge of cams is a little limited. With the stock pistons I know the lift is limited to about 510.
  9. #29
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,801
    Feedback Score
    17 (100%)
    Default
    With stock HO pistons you can run more than .510 lift. It's not peak lift that's the issue, as the piston is at the bottom of the cylinder at peak lift, it's duration. Duration is how long the value is open. For example I have stock style HO pistons in my car with inline cylinder heads that have 1.90" intake valves. The cam in the engine has .533 lift. Everything clears fine.
    As a FYI this is the Comp cam I recommended to you: https://www.summitracing.com/parts/c...view/make/ford
  10. #30
    Join Date
    Mar 2006
    Location
    Henderson, NV
    Posts
    212
    Feedback Score
    0
    Default
    Thanks for the heads up. After your message I started reading up on cams so I can understand them better. Looks like the one you recommend is just what I need. Do you think I will have a problem with the Trick Flow heads? They have 2.02 intake and 1.60 exhaust.
    Trick Flow® Twisted Wedge® 170 Cylinder Heads for Small Block Ford TFS-51410004-M61
Posting Permissions
  • You may not post replies
  • You may not edit your posts
