Page 7 of 7 FirstFirst ... 34567
Results 61 to 66 of 66
Thread: Fast EFI and ram air......
  1. #61
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,849
    Feedback Score
    7 (100%)
    Default
    I wouldn't run a K&N (or any oil charged air filter) on any car with a MAF, or especially any kind or forced induction. That oil ends up all over the MAF and skews it's readings one way cold, then the other way warm. I see this every day at work. There are lots of good high flow dry filters to choose from. If you go back to NA Speed Density, have at it, there's nothing to mess up.
    1988 Thunderbird 5.0
    GT40P, TFS-1, KB domes, 30#, MAF conversion, Explorer GT40 Upper/Lower, Smog delete, Wide Ratio AOD Mod, Unlocked Speedo, 3G Charging System Upgrade, Hi-Torque Mini Starter, 3.73 LSD, BBK 1 5/8 unequal headers, H-Pipe.
    88 Thunderbird/Cougar EVTM
    (Thanks to Trinom for hosting)
  2. #62
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,527
    Feedback Score
    135 (100%)
    Default
    I haven't seen any oils on my MAF. All of that is fine. I'll check it out again when I pull the CAI to replace it with the new BBK kit. Going back to Speed Density isn't even being considered. The car is running well.
    '88 Sport--T-5,HURST shifter,Trick Flow R intake,Ed Curtis cam,Trick Flow heads,Scorpion rockers,75mm Accufab t-body,3G,mini starter,Taurus fan,BBK long tube headers,O/R H-Pipe, Flowamaster Super 44's, deep and deeper Cobra R wheels, Mass Air and 24's,8.8 with 3.73's,140 mph speedo,Mach 1 chin spoiler,SN-95 springs,CHE control arms,aluminum drive shaft and a lot more..
  3. #63
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,801
    Feedback Score
    17 (100%)
    Default
    Quote Originally Posted by TheFoeYouKnow View Post
    Much of that has to do with people over oiling the filter after cleaning it. If done correctly according to K&N's instructions it's fine. I've never had an issue.
    The issue is the average person is quite stupid and doesn't follow directions.
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  4. #64
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,527
    Feedback Score
    135 (100%)
    Default
    Well, I tore the intake manifold, valve covers, coil, CAI, distributor and wires, and the radiator/fan assembly out of the Sport yesterday. I replaced the electric fan with a new Taurus piece, replaced the coil, and was about to install the new Trick Flow R lower intake and then I realized.....no gaskets for the lower intake. CRAP!!! Ran down town, no one had appropriate gaskets for the larger ports, so, I ordered a set from Summit yesterday evening, they should be here tomorrow. Then I can install the intake.
    I pulled the Moroso Ultra 40 wires and installed Livewires on the distributor cap, I'll fit the new strut tower brace later. The new CAI is a pretty easy install as well. I still have other parts that need to go on, fuel pump, ignition box, master cylinder, clutch, rear CHE control arm bushings, MGW shifter, all brake pads, window motors, speedo gear, and Traction Lock.
    One piece at a time and as always, it'll get done. I'm going to sell off my old CAI and probably the lower intake. It was TMoss ported. I'm keeping the GT40 upper to fab intake plates.More updates and pics later.
  5. #65
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,801
    Feedback Score
    17 (100%)
    Default
    Always have all the parts before starting
  6. #66
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,527
    Feedback Score
    135 (100%)
    Default
    Yeah, I know. I know. LOL.
    I always do......can't say that anymore. LOL. I may have been mistaken when I thought I had the lower intake gaskets. OR, I'll find them as soon as I button everything up. LOL.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
