Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 66
Thread: Fast EFI and ram air......
  1. #21
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,527
    Feedback Score
    135 (100%)
    Default
    I'm dropping all my coins in my can to save up.
    '88 Sport--T-5,HURST shifter,Trick Flow R intake,Ed Curtis cam,Trick Flow heads,Scorpion rockers,75mm Accufab t-body,3G,mini starter,Taurus fan,BBK long tube headers,O/R H-Pipe, Flowamaster Super 44's, deep and deeper Cobra R wheels, Mass Air and 24's,8.8 with 3.73's,140 mph speedo,Mach 1 chin spoiler,SN-95 springs,CHE control arms,aluminum drive shaft and a lot more..
  2. #22
    Join Date
    Oct 2004
    Location
    north carolina
    Posts
    515
    Feedback Score
    4 (100%)
    Default
    Hell Yea.......
    http://fitechefi.com/products/30003/ and I think you can just use the pump you have now
    1.7 roller rockers, cai, k&n, bbk adj regulator, 76mm Pro-m,all MSD ign. MSD dist,18 base timing, 3g alt.1 5/8 ceramic headers, 255lph walbro, 2.5" h-pipe, flowmasters, silverfox valvebody, 3.73 gear,
    http://i216.photobucket.com/albums/c...d/DSCF0185.jpg ( RIP : ( )
  3. #23
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,527
    Feedback Score
    135 (100%)
    Default
    I was looking at FITech as well as FAST. Still comparing them to see which one would be best. I like that system in the video. That would be right for my car.
    I have to answer questions like....
    Can I remove the current ECM and run the current pump? OR, do I need to run a new pump and start out from scratch as if I had a carbed car?
    What do I need to leave in the car as far as the main harness and ECM are concerned? I'm unsure at this time what I need and don't need from my car to do the conversion.
  4. #24
    Join Date
    Oct 2004
    Location
    north carolina
    Posts
    515
    Feedback Score
    4 (100%)
    Default
    I like the looks of the fast but alot more expensive.....
    http://www.speednik.com/files/2013/04/fast20-02.jpg
  5. #25
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,527
    Feedback Score
    135 (100%)
    Default
    I agree. I can be happy with either one as long as it will do it's job very well.
  6. #26
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,527
    Feedback Score
    135 (100%)
    Default
    I have a question with all of this FAST or FiTech swap stuff.....
    If I go that route, can the main engine harness and ECM be removed from the car? Does anything else depend on the ECM other than the engine? I do know my dash clock is tied into the harness, but I only use it as a clock, I don't use the fuel mileage stuff, so I'd guess that the two wires to the main harness could easily be removed. But the rest I'm unsure about like water temp and oil sending unit.
  7. #27
    Join Date
    Oct 2004
    Location
    Fort Wayne, Indiana
    Posts
    3,224
    Feedback Score
    9 (100%)
    Default
    i think youll need a portion of it, for the tfi and the gauges. but that I believe is it all that stuff is gone from my car anyway with the MSD, carb and aftermarket gauges but I'm not 100% its been a long while since I've seen a complete factory car
    87 LX 302, E7's, ARP bolts, Mallory Unilite Distributor, MSD 6A, Edelbrock Performer Intake, Edelbrock 600 Carb, Flowtech Long tubes, 5Speed, 8.8w/4.10's, Granatelli Tube K-Member & LCA's, Coil Overs, KYB 4ways, CHE arms, 3" rear drop springs, BBK C/C Plates, SN-95 5-lug stuff, Fuel Cell, Battery Relocation, Mac Mufflers, Stinger Tails, Sunpro gauges, Custom Lip Spoiler
  8. #28
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,527
    Feedback Score
    135 (100%)
    Default
    i'll replace the distributor. Possibly with one for an 85 Mustang GT. I have studying to do on that. Which gauges would be effected by removing the main harness?
  9. #29
    Join Date
    Oct 2004
    Location
    Fort Wayne, Indiana
    Posts
    3,224
    Feedback Score
    9 (100%)
    Default
    i believe just the temp and oil pressure gauges
  10. #30
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,527
    Feedback Score
    135 (100%)
    Default
    Crap.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
