Results 1 to 5 of 5
Thread: Drivers side mirror glass removal
  1. #1
    Join Date
    Jan 2017
    Location
    Albuquerque,NM
    Posts
    9
    Feedback Score
    1 (100%)
    Default Drivers side mirror glass removal
    Question:How do you remove just the mirror glass from the driver's side?Do you have to remove the door panel or is there an easier way for just the mirror glass?Its an 87 w/power mirrors.
  2. #2
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,283
    Feedback Score
    2 (100%)
    Default
    Push the mirror around. There are three large Philips head screws behind the glass if i remeber correctly.
    You can also simply unbolt the mirror from inside the car. Unscrew the single screw in the little triangle trim piece near the mirror from inside the car. Can't remeber where the clip is for the wiring, i wanna say its behind the door panel though.
    Quote Originally Posted by jcassity
  3. #3
    Join Date
    Jan 2017
    Location
    Albuquerque,NM
    Posts
    9
    Feedback Score
    1 (100%)
    Default
    Thanks very much.I appreciate the information.��
  4. #4
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,826
    Feedback Score
    17 (100%)
    Default
    You'll need to remove the door panel to get to the power window connector. It's about half way down the door.
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  5. #5
    Join Date
    Dec 2006
    Location
    Fairfield, Ca
    Posts
    2,074
    Feedback Score
    2 (100%)
    Default
    You can remove just the glass by pushing the part of the mirror glass by where it mounts to the door. Carefully but firmly grasp the mirror glass and pull it out with a snap. I've removed several that way without harm to the glass or my fingers.
    86' T/C 4.6L DOHC
    16' Chebby Cruze 1.4L Turbo
    “Heavy Metal Mistress”
Posting Permissions
  • You may not post replies
  • You may not edit your posts
