Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
Thread: Center console trim gray, what is the paint code?
  1. #21
    Join Date
    Feb 2012
    Location
    Monona, Iowa
    Posts
    481
    Feedback Score
    3 (100%)
    Default
    I will scan in the 83-86 interior DuPont charts I have next week sometime. Take the DuPont codes with you, they may be able to cross reference them to a PPG code.
  2. #22
    Join Date
    Oct 2004
    Location
    NE Ohio
    Posts
    6,191
    Feedback Score
    6 (100%)
    Default
    Alright, I had a semi-successful run to the auto paint store. They are mixing the interior paint at one location, then shipping it to another to have it put in an aerosol can. I'll get it early next week to actually spray it and see what we've got.
    After taking the sample books out in the sun and comparing it to 3 random 1985-88 interior panels (one of which is NOS), I'm about 98% confident we have a winner with Raven.
    PPG - 9520
    This color is sometimes listed as a truck interior color (Raven), and sometimes listed as just Black amongst other black shades, but the 9520 and 9612 codes consistently came up from 1985-88. Also, the two numbers were for low gloss and semi gloss, but again, those switched around from year to year. Just like the dealer books, everything was chaos up until 1985, and once we got to 1986 things were a lot more informative and orderly.
    So there we go. I'll get pix of the sprayed panel (before and after) along with a side-by-side comparison with the NOS piece for reference.
    Assuming this is all correct, the next step is to try and find the same or equivalent color in a commercially-available spray can (SEM, Duplicolor, etc.) for ease of use and widespread availability. But we'll cross that bridge when we get to it. For now I'm doing a very small, tightly-controlled victory dance.
  3. #23
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,826
    Feedback Score
    17 (100%)
    Default
    Awesome. The two local PPG guys mix spray cans on site so, if this is the correct color, it will be easy for me to get it made.
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  4. #24
    Join Date
    May 2016
    Location
    Lancaster, PA
    Posts
    229
    Feedback Score
    1 (100%)
    Default
    Awesome. As you said, if we have a match, trying to find the closest SEM (or other) commercially available spray can would be great.
  5. #25
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,826
    Feedback Score
    17 (100%)
    Default
    Any update Eric?
  6. #26
    Join Date
    Oct 2004
    Location
    NE Ohio
    Posts
    6,191
    Feedback Score
    6 (100%)
    Default
    Haven't had time to pick up the paint yet. Hopefully this week...
  7. #27
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,826
    Feedback Score
    17 (100%)
    Default
    Cool.
  8. #28
    Join Date
    Oct 2004
    Location
    NE Ohio
    Posts
    6,191
    Feedback Score
    6 (100%)
    Default
    Got the paint. Results below.
    I picked a nondescript, typical 1985-88 interior panel for an example. This is the rear ash tray for cars with consolettes. It's seen better days:
    After prepping, two coats of the new Raven interior paint:
    So far so good.
    Comparison with other, stock interior panels. One is the column cover, the other is an NOS floor shifter bezel:
    Another view:
    These photos were taken at high noon on July 3rd so there's no mistaking the high sun angle.
    I'm led to believe that this is indeed the correct interior color and finish. We have a winner with Raven.
  9. #29
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,826
    Feedback Score
    17 (100%)
    Default
    Thanks Eric!
    I'll get the local paint shop to mix me up PPG-9520 in a spray can.
  10. #30
    Join Date
    May 2016
    Location
    Lancaster, PA
    Posts
    229
    Feedback Score
    1 (100%)
    Default
    Sweet! Thanks for leg work on this one, problem solved.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
