Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Swapping 89 5.0 HO into my turbo coupe
  1. #21
    Join Date
    Jan 2018
    Location
    Clemmons, NC
    Posts
    41
    Feedback Score
    0
    Default
    Hey Ramos, what motor mounts did you end up using? I will be needing a set for my 88 TC with a 351C. Thanks!
  2. #22
    Join Date
    Aug 2013
    Location
    Fresno, Ca
    Posts
    344
    Feedback Score
    2 (100%)
    Default
    I ended up finding a used set of Chuck mounts for a 302. He doesn't make them anymore but I was lucky enough to find a set here on the forum.
    I'm not too familiar with the Cleveland engines so I'm not sure which mounts would be best for you.
    1987 T-Bird TC: 5-Spd, 5-lug conv., CHE Rear CAs, '04 Cobra wheels and 13" Brakes, Vac Assist conv: '93 Cobra BB/MC & Wilwood PV, Gutted/Knived Intakes, T3 turbo, RFE6 Mani, Stinger 3" Exhaust & Oil Feed, 255HP Walbro, Kirban AFPR, RR Cam, Esslinger Cam gear and Round Tooth Conv., Gillis Boost Valve, Speedway Dual Valve Spring, K&N, 130a 3g Alt conv., 140mph Speedo
    Running Better Than Ever
  3. #23
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,506
    Feedback Score
    14 (100%)
    Default
    Graham (88turbo) knows the specific of using a truck 5.0 fuel rail in a 2.3 to 5.0 conversion. Basically the idea is that the truck rail mounts to the existing 2.3 lines on the firewall (or wherever they come up from) rather than dealing with the work of making new ones to come up on the passenger side to match the Stang/Bird 5.0 units
    This is what I've read and been told, haven't put it to work myself...
    Ramos, I believe you were the feller who got my Chuck's mounts when I sold off my stuff, right? Glad to see it get used
    '84 and '87 Mustangs
    '98 Explorer
    FORD forever!
  4. #24
    Join Date
    Aug 2013
    Location
    Fresno, Ca
    Posts
    344
    Feedback Score
    2 (100%)
    Default
    Yes sir, thank you they worked out perfect. Car is almost road worthy.
  5. #25
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,506
    Feedback Score
    14 (100%)
    Default
    Excellent!
    '98 Explorer
    FORD forever!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
