Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Tapping explorer intake for ACT
  1. #11
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,850
    Feedback Score
    7 (100%)
    Default
    Some of the aftermarket intakes give up runner length and plenum volume for max horsepower, the GT40 doesn't. Even with all that's available, the GT40 is still one of the best "all around" intakes in terms of torque vs RPM. After all, Horsepower isn't real, it's the result of a calculation (which is why torque and HP are always equal at 5750rpm).
    1988 Thunderbird 5.0
    GT40P, TFS-1, KB domes, 30#, MAF conversion, Explorer GT40 Upper/Lower, Smog delete, Wide Ratio AOD Mod, Unlocked Speedo, 3G Charging System Upgrade, Hi-Torque Mini Starter, 3.73 LSD, BBK 1 5/8 unequal headers, H-Pipe.
    88 Thunderbird/Cougar EVTM
    (Thanks to Trinom for hosting)
  2. #12
    Join Date
    Sep 2006
    Location
    Olathe, Kansas
    Posts
    2,408
    Feedback Score
    3 (100%)
    Default
    Quote Originally Posted by TheFoeYouKnow View Post
    Also, while you're drilling and tapping, you should consider opening the coolant port for the EGR cooler, it's there on the Explorer intake, but like the ACT, it's just a flat boss, so you're left with a return fitting on the coolant manifold, but no coolant feed. I don't recall the drill size, but I'm pretty sure the tap was 1/8 NPT.
    Is that for all explorer intakes, I haven't heard that one before.... Please share.
    Mike
  3. #13
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,850
    Feedback Score
    7 (100%)
    Default
    All of them. On the HO lower, the front nipple for the EGR cooler is in the coolant tubes that run down that side of the intake, but the feed fitting is in the intake toward the rear. On GT40 intakes, this is not drilled and tapped, but it is there as a flat spot.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
