Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 29
Thread: doesnt idle cold, hard start, IAC adjustment?
  1. #11
    Join Date
    Mar 2015
    Location
    braintree ye olde england
    Posts
    132
    Feedback Score
    0
    Default
    Google eec-iv codes. This will tell you how to pull codes without the code reader also check out diy stuff on this site.
  2. #12
    Join Date
    Oct 2004
    Location
    Southern Maryland
    Posts
    2,669
    Feedback Score
    0
    Default
    Maybe this will help:
    Attached Images Attached Images
  3. #13
    Join Date
    Oct 2004
    Location
    East Coast Virginia
    Posts
    10,228
    Feedback Score
    0
    Default
    Quote Originally Posted by bootleggers deluxe View Post
    sounds like i need to check fuses, i know in newer cars, there is a fuse that powers the OBD port. however, since using a scanner on these involves an external power source, i would think that it wouldnt be the same issue.
    There is no power in a OBD-I test port, scanner has to be self powered or have a battery connection... Some computers just won't communicate with the scanner, had that problem with my '93 lightning and the pocket sized scanner I used on my Bird... Using a OTC it was fine... You can call me lazy but chance I'd ever go back to counting blinks are zero & none...
    With a idle issue you need to be sure the base idle is up to spec... That's the idle speed without the ISC assisting...
    My other rides (that actually do run & drive)
    1969 Fairlane Cobra 428CJ 4-Speed << New 49th Birthday Picture
    1972 Comet GT - 306 C4
  4. #14
    Join Date
    Nov 2016
    Location
    Iowa
    Posts
    165
    Feedback Score
    0
    Default
    Softtouch, that was extremely helpful, thank you. I will be doing that tomorrow morning.
    Tubrocoupe50, i would like to think my Blue point scan tool that is capable of doing both OBD1 and OBD2 would be capable enough to accomplish such things, however, i shouldnt always put my faith on whatever comes off that big white truck with red letters.
    You mentioned bumping the base idle up, where is the adjusting screw for that? i looked and got stumped. I think the idle seems a bit low, i would love to bump it up a bit.
    Ive been driving the car about 150 miles over the weekend, it has been a bit easier to start ( 2-3 attempts, instead of 15-20) but i still need to assist with a foot pump to get it going, and i need to hold a high idle manually with the gas pedal for a few minutes to get it properly warmed up before taking off. other than that, it seems to run flawlessly, it cruses nicely. I'd just like to get the hard start and idle issues sorted out.
  5. #15
    Join Date
    Oct 2004
    Location
    Southern Maryland
    Posts
    2,669
    Feedback Score
    0
    Default
    There is no "base idle adjustment" with the 3.8L CFI Idle Speed Control motor (ISC) system.
  6. #16
    Join Date
    Nov 2016
    Location
    Iowa
    Posts
    165
    Feedback Score
    0
    Default
    ok peeps, so i got it good and warmed up, a nice 10 mile drive, and followed the instructions above. made a jumper wire, put it into "test mode" and the plunger did not retract on the IAC. wheres my next move?
  7. #17
    Join Date
    Oct 2004
    Location
    Southern Maryland
    Posts
    2,669
    Feedback Score
    0
    Default
    Have you ever seen the ISC plunger move?
    Hook up a test light or an analog volt meter to see if you are going into test mode.
    You should see the light blink or the meter needle sweep as it outputs codes.
    If no codes; try jumpering the pigtail wire to ground instead to the six pin test connector.
    Does it now output codes? If so, this indicates a blown signal return land pattern in the EEC computer
    When you put the ignition switch in run (without starting) can you here the fuel pump start and then shut off after a couple of seconds? normal
    Or does it run continuously? not normal
    This sounds like a bunch of dumb stuff to do but it tests the condition of your EEC.
    By the way; your car doesn't have an IAC (Idle Air Control). That is used on EFI and SEFI engines not on CFI.
  8. #18
    Join Date
    Oct 2004
    Location
    East Coast Virginia
    Posts
    10,228
    Feedback Score
    0
    Default
    Quote Originally Posted by softtouch View Post
    Uhhh yeah, having never owned a 3.8(no I won't touch one) I forget these things...
  9. #19
    Join Date
    Nov 2016
    Location
    Iowa
    Posts
    165
    Feedback Score
    0
    Default
    ok, Softtouch, heres what i got to answer your questions.
    I cannot say i have ever seen the plunger move in the idle air thingie since i installed it. the one that was on the car when i got it made a very loud buzzing noise, i was told that that was a pretty sure sign it had failed, and so i took the chance and replaced the part.
    I will follow your test procedures with a test light next time i am working on the car, i will let you know the results from both the test wire , and from grounding out the test wire.
    The fuel pump does run for 3-4 seconds and shut off, which i have considered a proper priming, but i guess i may be incorrect on this particular model.
    your diagrams have been extremely useful for me, please keep them coming. I'm a professional mechanic, but i only deal in undercar (brakes, suspension, exhaust, alignment, etc) and have never had a lot of hands on experience or training in engine diagnostics. however, i do understand the basics, and will gladly walk through whatever steps have been placed in front of me. so for that, i thank you.
    Also, a new symptom today. I was driving the car home (approx 10 miles, highway speeds, car was running in town for about 10 minutes prior to that) the car seemed like it was running out of fuel while going 55 mph. i stomped on the gas and it motored out of it, but it happened a total of three times in the last two miles of highway driving home. once it was back home, it sat and idled like nothing happened.
  10. #20
    Join Date
    Nov 2016
    Location
    Iowa
    Posts
    165
    Feedback Score
    0
    Default
    Quote Originally Posted by TurboCoupe50 View Post
    Trust me, the 3.8 is far from my favorite engine. my parents both had a lincoln contiental with them in it (92 and 93) and they both blew the head gaskets at the same time. fun stuff, doing back to back head gasket jobs.
    i keep thinking that if i dont get this thing to run right, i should grab one of my spare 351Windsors and shove it in. I can tune a carb.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
