Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 41
Thread: new to me 88 Tbird, pondering brake/wheel upgrades.
  1. #31
    Join Date
    Nov 2016
    Location
    Iowa
    Posts
    165
    Feedback Score
    0
    Default
    So, bringing this thread back.
    I bought a set of 98 Mustang front spindles and a 98 mustang 7.5 with factory discs. Was originally going to swap all that in, and eventually look at a different rear when the 7.5 decided it was no longer happy.
    i'm now getting a turbo coupe 8.8. I like the idea of an 8.8, especially because I'm looking at a manual trans. But i'm set on converting to 5 lug.
    i'm reading this:
    http://www.coolcats.net/modifying/4to5lug.html
    Did i read this correctly? i can take my 7.5 axles out of my mustang axle, and put them into this 8.8? and then run the mustang brake parts?
  2. #32
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,383
    Feedback Score
    4 (100%)
    Default
    Direct swap. Strip your TC rear down to the axle housing with the gears left in it. Do the same with the SN95 7.5 rear. Swap the SN95 axle brackets onto the 8.8, install the SN95 axles and c-clips, install the &.8 cross pin and retaining bolt with some new loctite. From here reassemble the SN95 brakes. I would suggest rebuilding the trac-lok while you are this deep into the 8.8 but thatís just me.
  3. #33
    Join Date
    Nov 2016
    Location
    Iowa
    Posts
    165
    Feedback Score
    0
    Default
    It's been rebuilt, i think. if not, I'll definitely be giving it a refreshening.
    I'm glad i dont need to go track down axle shafts. makes my life a bit easier.
  4. #34
    Join Date
    Nov 2016
    Location
    Iowa
    Posts
    165
    Feedback Score
    0
    Default
    Quote Originally Posted by Aerocoupe View Post
    There is another solution which is keep the Fox Inner tie rod and use the Maximum Motorsports tapered style bumpsteer kit which is what I used on my Mustang with SN95 spindles prior to switching to their full suspension up front.
    http://www.maximummotorsports.com/Bu...tyle-P449.aspx
    Me personally I would get the bumpsteer kit as new inner and outer tie rods will cost you about the same and you have the advantage of setting the bumpsteer. You do not need the bumpsteer gauge for a street car as you can eyeball it and get it damn close like I did. Setting them up with the gauge is better but not worth the effort for a street car that will not be on a track if you ask me. Also, bumpsteer is more noticeable on roads with crowns and potholes than smooth surfaces on a street car. So with that I would be way more concerned with bumpsteer on your worn out Iowa two lanes than a new four lane.
    I didnt mention this before, but i did pick up a bumpsteer kit this fall. I actually found a local guy selling fox body parts, got a Saleen rack, the bumpseer outer tie rod parts, and a set of new offset rack bushings for $100.
  5. #35
    Join Date
    Nov 2016
    Location
    Iowa
    Posts
    165
    Feedback Score
    0
    Default
    Ok, im close to having all the required parts to do the front swap, but i need to know, what shims should i use for the front struts, when going with the 98 mustang spindles? The struts are brand new, so i dont want ot go buy a set of mustang struts.
  6. #36
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,383
    Feedback Score
    4 (100%)
    Default
    You are needing the strut shims. Used to be able to find them but not so much any more. You need two 1/8” shims per side so get some 1/8 plate or strap, cut to size, drill holes, and install. Some have used washers but if it were me I would make the shims.
    One thing to remember is struts are valved for spring rates so matching them is pretty beneficial. If you have struts for a V6 or a 4 cylinder then using them with V8 springs will not be ideal.
  7. #37
    Join Date
    Nov 2016
    Location
    Iowa
    Posts
    165
    Feedback Score
    0
    Default
    I actually ordered the struts in anticipation for the v8 to go in, so they are set in that aspect.
    I was hoping someone, somewhere made the shims, but no bother, i'll just make some myself then.
  8. #38
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,383
    Feedback Score
    4 (100%)
  9. #39
    Join Date
    Nov 2016
    Location
    Iowa
    Posts
    165
    Feedback Score
    0
    Default
    Aero, you're my hero!
  10. #40
    Join Date
    Nov 2016
    Location
    Iowa
    Posts
    165
    Feedback Score
    0
    Default
    waking this thread up again...
    My parts stash is ever growing, it seems. I now own three different axles i was planning on swapping in the car, first the 7.5 out of a 98 mustang, then an 88 TC 8.8, and now, a 94 Mustang 8.8 thats been beefed up with 4.10s.
    I also have my 98 mustang spindles, as well as a set of 94 mustang spindles. the 94 spindles are ideal, correct? or should i go with the 98 spindles still? i plan on lowering the car an inch or so using 98 mustang springs, and i do have a bumpsteer kit and a new rack to swap in.
    Here's the wheels i plan on running. 17's off an 08 mustang. i have two sets of em now.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
