Page 3 of 12 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 120
Thread: 84 XR-7 Project
  1. #21
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,283
    Feedback Score
    2 (100%)
    Default
    My 86 is like that. I've had other cars where the door was hard to open and shut when jacked up. My cougar I can't open or close either door while it's on jack stands. My last 87 bird didn't seem to care at all when it was jacked up. Doors opened and closed like normal.
    Quote Originally Posted by jcassity
  2. #22
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,826
    Feedback Score
    17 (100%)
    Default
    Quote Originally Posted by Haystack View Post
    I think the 87-88 cars must have been slightly stiffer. My Thunderbird didn't really flex at all on jack stands before subframe connectors.
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  3. #23
    Join Date
    Dec 2004
    Location
    Lehighton, PA
    Posts
    347
    Feedback Score
    0
    Default
    Well I can confirm that. My 87 felt like a tank compared to my 84. It didn't handle better but it rode a lot quieter. The steering was heavier too.
  4. #24
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,826
    Feedback Score
    17 (100%)
    Default
    Probably explains why the 87-88 cars were a couple hundred pounds heavier.
    Back on topic. How are you replacing the rusted floor boards?
  5. #25
    Join Date
    Dec 2004
    Location
    Lehighton, PA
    Posts
    347
    Feedback Score
    0
    Default
    Didn't get near as much done this weekend as I had hoped. But we did start working on the driver's quarter. Got that pretty well straightened out. I had to work on a family member's car Saturday, which took a lot longer than I wanted. Kind of stuck at the moment anyway. Still trying to find a place or person to help with getting the metal I need for the SFCs. I'll have a ton to do once those are done. I don't think I have anything major this coming weekend, so hopefully we'll make some good progress.
    Quote Originally Posted by thunderjet302 View Post
    They aren't too bad. Just going to cut out the bad and make patches with sheet metal.
  6. #26
    Join Date
    Dec 2004
    Location
    Lehighton, PA
    Posts
    347
    Feedback Score
    0
    Default
    Some good luck came my way this weekend. I don't have it in my possession yet, but I have found a donor vehicle! This is a great weight off my shoulders. I had a moment of giddiness once I found out, like I finally can say "OMG this is actually going to happen!" Pics coming in a few days, I'm not sure exactly when it is going to get dropped off.
    I also have a question concerning the transmission tunnel. Does anyone know if the Mustang 5 speed transmission hump fits my floor? I don't want to buy one and it not fit. I won't need an extra one. I have a '90 GT and a '91 LX, they are manual and auto respectively. The LX is getting parted and sent to the crusher. I might have to take the one off the GT to try it. If not, I guess I'll just have to cut the opening and figure out a way to better seal the hole to the shift lever coming out of the transmission.
  7. #27
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,283
    Feedback Score
    2 (100%)
    Default
    I didn't use anything in addition to the lower shift boot seal and I had no issues. I actually just siliconed it to the floor, forgot to get some bolts for it and forgot all about it.
  8. #28
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,826
    Feedback Score
    17 (100%)
    Default
    Does the donor have an Ecoboost?
  9. #29
    Join Date
    Dec 2004
    Location
    Lehighton, PA
    Posts
    347
    Feedback Score
    0
    Default
    No boost, at least on this first engine build. But displacement will be doubled, HP more than doubled.
  10. #30
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,826
    Feedback Score
    17 (100%)
    Default
    Quote Originally Posted by Billyf17 View Post
    5.0 I'm guessing?
    A 2.3 Ecoboost would be a cool swap to replace the 2.3 Lima.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
