Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: talk to me about UPS' (uninterrupted power supply)
  1. #11
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,501
    Feedback Score
    15 (100%)
    Default
    late reply,, but
    with your desktop it just needs ac power.
    your chosen UPS system will become the new power source.the UPS takes in utility power then converts that AC to stored DC.
    The stored DC is then converted to AC again and out to your machine. You can hand make a more reliable UPS with stuff you already have If you don't mind since I know your a can do guy.
    The issue you have is utility feeder issues so not only will it kill sensitive electronics but the NEW appliances are also at risk of failure due to transients and Neutral current surges (momentary surges in current flow on your neutral leg) and with a ground rod outside reading greater than 100 ohms, replacing your home ground rod should be the first step in full facility protection. Next would be to upsize the physical ground wire from your meter base or sub panel and home run that to the ground rod with idealy a Cad weld but acorn fittings seem to be normal in shitty install applications (ie- everyone's home). so many people out there pay no or little attention to grounding.
    Now that your ground is stable, your input to your chosen UPS can "suffer less" and may possibly be able to handle minor power issues like brown outs or intermittent phase voltage/current changes. The walmart variety UPS input circuit is somewhat sensitive to input power stability and you can only control so much. that's why I say that making your own UPS would be better because you can use older tech that would be able to absorb input power problems without overcomplicated TTL technology or switchmode power supply driven devises which are less capable of living through many input power problems.
    a homemade UPS would look like this.....
    -12v battery charger input sourced from your 120v outlet., you would want an older working charger because these are less sensitive to input power problems and can take a hit when it does happen.
    -12v battery charger output tied to your 12v battery of choice & a on off switch on the red wire including a 5amp or 10Amp fuse... all in series
    -12v battery posts bond to your inverter input red / black.
    -inverter output outlet becomes your desktop input power.
    --- when utility is on, depending on your charger type, ideally your charger is the primary inverter source for power... amps is everything.
    --- when utlity is lost, the battery becomes the primary source and discharges upon the inverter and your still making power for a long time, enough time to wrap up and shut down If you want.
    --- disadvantages are with 12v auto batts is H2 gas,, so a VRLA battery would be better, I personally would worry too much about a flooded cell battery in my house.
    Quote Originally Posted by CoogarXR View Post
    I have been in the IT field for almost 20 years professionally. I have lived through more hardware failures than the average cat. Plan for it, because it WILL happen. You can never have too many backups.
    and ive been working along side your staff for longer and I will slightly contradict what you said ,,,,
    It is possible for perfectly good hardware to crash just because oem firmware and / or software is no longer supported thus becoming what appears to be a broken device to the "new update"
    Example, I had a win XP SP1 HP desktop that at some point several years ago I started getting IE messages and Google notifications that my system will no longer be supported soon. I stopped doing Win XP SP1 updates shortly after and eventually stopped doing updates at all because many updates are based on assumptions that you are buying new shit all the time and creating more planetary garbage. I kept my Malwarebytes account updated and it ran really strong and protect my old slow HP machine until a year ago I did an update... that very update crashed my machine and tech support at Malwarebytes actually confirmed it. End result was that the update I was doing was like putting a round peg in a square hole. Firmware is the biggest hassel and software updates follows second. Yes hardware fails be everyone be advised that those invisible little 1's and 0's can kill a perfectly good machine as well. The older the machine the less support and the more time you need to take to "step into" levels of firmware or software updates.
    An external tera drive allowed me to keep all my files so the old HP became scrap parts.
    I feel for the IT industry, I almost went that route for employment years ago and decided I didn't think it was a good fit for me so im in critical facilities power & construction which I design engineer for various telecom providers.
  2. #12
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,506
    Feedback Score
    14 (100%)
    Default
    On the bright side, my house hasn't had lightning run into it since 2003. The downside; about once every two weeks, the power drops out for a brief span between a second, up to a couple of minutes.
    Yet another fucking hard drive has been replaced. Thanks, Farmer's Electric Co-op, for the no lube, shove it in hard and fast and not give the twig and giggleberries a feel...
    They won't replace my stuff. Currently have the laptop loaned out to a friend, too. Not that it's any kind of hotrod, it's actually a piece of crap, but at least if I'm online and the power cuts out, it won't die horribly..
    Otherwise, things are ok...got some issues on a personal level that I've got to contend with, but you know me...I always survive. Be safe y'all.
    '84 and '87 Mustangs
    '98 Explorer
    FORD forever!
  3. #13
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,282
    Feedback Score
    2 (100%)
    Default
    I think my record for constant online time was about 8 years. Back in the day we had a separate dial up line with its own dedicated server. I built a 75 mhz server I built with all ultra wide scuzzy parts that ran constantly. It shared the connection with all the other computers through a 24 port professional hub downstairs with another 10 porridge hub upstairs. I used to throw lan party's where noone had to bring a computer. I actually got kicked off of comcast for using too much bandwidth and having 36 unique ip address online at once.
    In all that time, i never lost a computer or power supply to lightning or an electrical surge. Most of my computers did run a surge protector though.
    Quote Originally Posted by jcassity
  4. #14
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,506
    Feedback Score
    14 (100%)
    Default
    I've got surge protectors, but my issue is the power just cuts out. Started last summer, there was a faulty transformer, then something happened, and all 4 houses on this bit of road had to have all the transformers replaced at the same time.
    THEN a possum tried climbing from the wire on a pole to the transformer, that caused another power loss, and we were out for about 4 hours till a crew came out and found the issue. Was on a weekend, likely they had to bring a crew in from somewhere else as the local guy lives in a beer can on his days off...
    Then not long after, we had a storm and it blew a tree into a line about a mile from here, another few hours without juice.
    Really, me power issues are sort of like the issues Vinnie had with his last engine....just small things, but they've piled up in my head and I'm rather pissed about it.
    What can I do though? Wind generators are a lot of money, but I'd love to be able to sell excess electricity and not have to pay a bill. Then again, when those big bastards go, they go spectacularly.
    As far as constant uptime, I think back in 2006 when I was doing a lot of music streaming (I was the dj, not the listener) I had my rock solid XP Pro system up for about 3 months before I shut it down one day to add another drive for music capacity.
    The Win 7 Ultimate system I have now is pretty good, all these updates can kiss my ass, but all in all, it's alright, the only thing I really have to complain about is...the problems on the electric coop's end. I've complained a few times, they've told me they had crews out to inspect, and they've replaced some sensors and of course about half a dozen transformers over the past year or so. It's been nearly two weeks since we had a power loss this go 'round, so maybe they have their shit in order now, and we have had some pretty wicked storms the past couple of weeks. About 1Am a nice big thunderpopper ripped through, gotta head outside here in a few to see how many more maple limbs blew down...I've got a nice brushpile out back of the "garden" *, should make the kids happy when we have out hot dog roast here in a couple of weeks for my birthday.
    *Garden disclaimer: We had some stuff planted, but apparently the deer were hungry. All we have left are TWO "tomater" plants and I put cattle panel around those with some pie pans tied to 'em to make noise...saw a small deer last night out in the backyard while I was letting a dog out, almost found out how well a 147gr +p works on whitetail..lol.
    '98 Explorer
    FORD forever!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
