Page 38 of 48 FirstFirst ... 28343536373839404142 ... LastLast
Results 371 to 380 of 479
Thread: 87 "coug" resto winter project
  1. #371
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,501
    Feedback Score
    15 (100%)
    Default
    this one is marked F8....xxx pn.
    i think its the explorer fuel rail.
    fuel rail has built in shrader valve fp test port.
    the feeder lines do not have a shrader fuel pres test valve.
    has a 2 bolt regulator
    lines come in from driver side,, seems like a rather hard fitment.
    I like the idea if fuel feeds coming in from the rear though.
    Attached Images Attached Images
  2. #372
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,501
    Feedback Score
    15 (100%)
    Default
    no markings on this anywhere,
    has a 3 bolt regulator which is compatible with the CFI 3.8 or 5.0L which all oem were
    adjustable by allen wrench, aftermarket were not.
    no shrader valve fp test port
  3. #373
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,501
    Feedback Score
    15 (100%)
    Default
    this one seems stock, marked as F4xxx
    has two bolt fp reg.
    has shrader fp test valve
  4. #374
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,501
    Feedback Score
    15 (100%)
    Default
    here are a couple CFI FPR which are 3 bolt and adjustable, fit the 3 bolt rails but do not need vac presure.
    I seem to think that i would "want" an adjustable FPR,, right?
    so, which fuel rail do i go with,,,,?
  5. #375
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,268
    Feedback Score
    2 (100%)
    Default
    I like the idea of an adjustable fuel pressure regulator, but I probably wouldnt use one.
    The vacuum is essentially an built in adjustable regulator. When you are on the gas, you lose vacuum, it automatically adjust fuel pressure to suit. The computer knows what it needs. You start messing with the fuel pressure,bit no longer does.
    The computer can only compensate for about 10% difference from the oem tune. That's part of the reason I hate the 10% ethonal garbage we have here. It makes up a whole 7% leaving you for just 3% or so.
    Quote Originally Posted by jcassity
  6. #376
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,501
    Feedback Score
    14 (100%)
    Default
    The pic in post 371 looks like a truck fuel rail, hence why the connections are at the back driver's side...
    The pic in 372 will work assuming you have stock fuel line location in the car...
    The one in 373 looks as if it would work with a little tweaking of the angles of the fuel lines, as well, though I've never seen one exactly like that.
    I've heard of folks using the truck 5.0 rail in a TC, as the 2.3 cars have their fuel lines running up on the firewall, nearest the driver's side, IIRC..
    '84 and '87 Mustangs
    '98 Explorer
    FORD forever!
  7. #377
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,501
    Feedback Score
    14 (100%)
    Default
    Quote Originally Posted by Haystack View Post
    A lot of the adjustable regulator's need would determine what pump you have, look at Vinnie's setup....if uses that big FP he's talking about, he's going to need an adjustable if he doesn't have one on already...
    I don't think a SD EEC compensates for a whole low in regards to fuel pressure. It merely can be tricked into cycling the injectors for a certain duration. Would require flashing the chip though.
    Mass air EEC though is a different ballgame, and Scott had ought to be on that path, with a stroked engine...
    Basically, I had a SD HO in my 'Sport with a 255 Walbro pump, ran like a scalded cat and didn't need a afpr. Never tuned on it, so I'm not going to say it would've ran better with a little less or more...who can say.
    '98 Explorer
    FORD forever!
  8. #378
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,501
    Feedback Score
    15 (100%)
    Default
    yes, going mass aiir,
    the one in 373 is a go now,, and its marked with all the ford pn's and such, like its a stock thing
  9. #379
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,501
    Feedback Score
    15 (100%)
    Default
    I decided to go with this fuel rail.
    and,, did you all know............................................
    **inside the vac acuated fuel presure regulator there is a screen on the large opening? A filter so to speak,,
    swapping over the blue top injectors now.
    hope i dont screw myself by going with a two bolt FPR, this one will require vacuum like normal but i really wanted to be able to recycle the CFI FPR's if you all thought it would be useful. these FPR's for early CFI applications are pertty cheap to buy at the box stores.
    I took one a part one day for the heck of it, to see how it worked and if i could recycle one into a hydraulic ram valve we have down in the creek,, i noticed it also has a filter.
    thats when i was telling people to just shit can thier injector screens, the fuel is getting filtered three times,, once at the tank sock, once at the fuel filter then once again a the FPR.
    the fuel pump i have is walboro,, i need to look it up but 175lph sounds about right,, maybe 200, not that this car needs that.
  10. #380
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,501
    Feedback Score
    15 (100%)
    Default
    apparently cfi V6fuel lines are much much longer than 5.0's. I am trying to follow the same fuel line path as the 5.0, 3.8L came in behind the pass strut tower.
    i tried to keep that and it simply looked like crap.
    i have plenty of hose to reach the fuel rail extentions by following the 5.0 path., but not without some customiztion.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
