Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 69
Thread: Help! 7.5" Axle to 8.8" Trouble!
  1. #21
    Join Date
    Oct 2004
    Posts
    337
    Feedback Score
    0
    Default Re: Help! 7.5" Axle to 8.8" Trouble!
    Quote Originally Posted by JeremyB
    The only reason I say all the rears are the same is from corral.net/corner-carver.com searches and Kirschenbaum. I hope the threads I linked to you over on the Corral put your mind at ease.
    Sorry for my ignorance, but Im trying to clear this up for everyone...
    From what I understand the 8.8 mustang rear, 7.5 mustang rear, 8.8 turbo coupe rear, and lincoln lsc rears are all the same width. BUT the tbird 7.5 rear is not on that list. The mustang 8.8 and tc 8.8 are identical in width, but the axles on the TC are longer due to disc brakes. Since the tbird 7.5 does not have disc brakes, it still needs to be the same overall width as the TC rear, but the rearend itself is wider to compensate for no disc brakes. Therefore 7.5 rearend axles will not work in a 8.8TC rear properly without mods. So I think the best alternative is to use 8.8mustang axles in a TC 8.8 if one wants to retain drum brakes. Agree?
    1988 Tbird Stock bottom end 306, Windsor Jr's, Explorer intake, 125 shot.
    Best ET: 12.11 Best MPH: 113.8 1/4 mile
  2. #22
    Join Date
    Jun 2005
    Location
    Olympia WA
    Posts
    673
    Feedback Score
    0
    I think you got it exactly. Mustang axles go right in. If you are staying with the 28 spline than pick up a couple of used axles at the yard. This way if for some reason you theory does not work you are not out much. In fact you could just pick up one to try for now. If you are going with the 31 spline than I used Superior axles.
    Very good information, sorry you had to go through all this.
    TED
  3. #23
    im gay as hell Guest
    so theres no way to convert to 5 lugs with a 7.5 rear in a tbird with out changing axle size
  4. #24
    Join Date
    Oct 2004
    Location
    Indpls, IN
    Posts
    8,133
    Feedback Score
    34 (100%)
    Quote Originally Posted by im gay as hell
    Yes there is...use 94+ Mustang axles.....same length as those in the Tbird..... I converted the 7.5 in the 84 XR-7 with axles from a 95 Mustang.......
    Long live the 4-eyes! - '83 Tbird Turbo
  5. #25
    Join Date
    Oct 2004
    Location
    Omaha, NE
    Posts
    187
    Feedback Score
    0
    But chuck, weren't the T-bird/Cougar 7.5 rears the same dimensions as the Mustangs up until mid-year of 1985? That guy is talking about his 87 T-bird. The 94 and up axles worked in your 7.5 because it's of the early years; I don't thing this kid will have the same luck.
    Joe
  6. #26
    will it work or not
  7. #27
    or what other shafts can i use from what other models of car
  8. #28
    Join Date
    Oct 2004
    Location
    NE Ohio
    Posts
    3,702
    Feedback Score
    3 (100%)
    ....*sigh*
    Now this thread makes baby Jesus vomit.
  9. #29
    Join Date
    Oct 2004
    Location
    Indpls, IN
    Posts
    8,133
    Feedback Score
    34 (100%)
    Quote Originally Posted by joefriday
    Joe
    You know, I never measured the damned thing.... I took an 84 Cougar XR-7 7.5 rear axle housing, stuck 95 Mustang axles in it and am running the TC rear disks.....did not have to use any spacers or voodoo.
    It did have the taller hat drums on it though.
    I do have to admit all my cars have been 83-85....so I have no firsthand experience with the 87-88 cars when it comes to the rear axles.
    I suppose he could just pick up a used 7.5 Mustang housing cheap and be done with it....
  10. #30
    but no one knows which axles shaft you can swap wright in to make this so much easier
Posting Permissions
  • You may not post replies
  • You may not edit your posts
