Page 9 of 9 FirstFirst ... 56789
Results 81 to 86 of 86
Thread: BlueBird
  1. #81
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,823
    Feedback Score
    17 (100%)
    Default
    Christ. I should have gone back and reread
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  2. #82
    Join Date
    Mar 2006
    Location
    indy, IN
    Posts
    2,226
    Feedback Score
    4 (100%)
    Default
    A couple package deliveries later, I have more parts on the car
    Front Konis
    Cutting and flaring lines in the engine bay sucks while the engine is still installed...
    I also made up a couple brackets for the rear flex hoses at the calipers
  3. #83
    Join Date
    Mar 2006
    Location
    indy, IN
    Posts
    2,226
    Feedback Score
    4 (100%)
    Default
    Here they are installed, and you see the rear Konis too
    I kept the right axle tube mounted chassis hose and reused the axle hard lines from the original 7.5
    The new brackets hold the connection between the new caliper flex hoses and the shortened hard lines.
    It's pretty tedious bleeding brakes solo when you forget the racecar bleeder bottles at work, but I got it done enough to take a short test drive from the flat stall onto the lift.
  4. #84
    Join Date
    Mar 2006
    Location
    indy, IN
    Posts
    2,226
    Feedback Score
    4 (100%)
    Default
    Going up! Time to start soaking exhaust fasteners and scheming plans for some more of these parts I bought
  5. #85
    Join Date
    Oct 2004
    Location
    Indpls, IN
    Posts
    8,131
    Feedback Score
    34 (100%)
    Default
    Quote Originally Posted by gumby View Post
    I'm going to need to do that too.
    Progress looks good!
    What engine is in this thing?
    Long live the 4-eyes! - '83 Tbird Turbo
  6. #86
    Join Date
    Mar 2006
    Location
    indy, IN
    Posts
    2,226
    Feedback Score
    4 (100%)
    Default
    Cfi 3.8
Posting Permissions
  • You may not post replies
  • You may not edit your posts
