Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: MegaSquirt II
  1. #11
    Join Date
    May 2008
    Location
    Brno, Czech republic
    Posts
    657
    Feedback Score
    2 (100%)
    Default
    Bosch LSU4.9 isn't the best idea I think. It may have some advantages (no calibration required), but has many drawbacks. The biggest issue is its short service life.
    '85 Thunderbird TC '86 Thunderbird TC '97 Scorpio 2.3 GHIA
    T-Bird / Cougar DIY stuff
  2. #12
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,382
    Feedback Score
    4 (100%)
    Default
    I am going to run a wide band O2 on each exhaust bank and leave them installed all the time. The MS can take the signal from them and use them so that each bank has its own signal which makes for easier tuning via the data logging. These will simply replace the stock O2 sensors. There are several guys with Mustangs doing this for some time now and like the results and so far the wide band O2's are surviving just fine. I believe they are using the Innovate LC-1's but I will keep digging around to see if there are other options. Not necessarily cheaper, just better.
    Darren
  3. #13
    Join Date
    Jan 2006
    Location
    Vancouver, WA
    Posts
    941
    Feedback Score
    3 (100%)
    Default
    Darren,
    I am currently "stalled out" with my EFI swap using MS 3.57. I believe I just need to add some RF filters on the Crank sensor wire and she'll run, but I'm glad I have other vehicles so I can walk away from it for however long I feel the need to. I'm just going to use a single LC-1 wideband for now.
  4. #14
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,501
    Feedback Score
    15 (100%)
    Default
    anyone with updates.... i remember wanting to go to MS back in the early 2000's but back then they did not yet have a ford setup for TFI ready out of the box... lots have changed since then.
  5. #15
    Join Date
    May 2010
    Location
    Worcester. MA
    Posts
    841
    Feedback Score
    1 (100%)
    Default
    I'm still runnin ms2. Forget witch version. Remote Tfi. I assembled my own board.
    87 Turbo Coupe through the floor sub frame connectors, 5.8 swap Ford racing heads Harland sharp 1.6 rockers BBK shorty swap headers 2 1/2 BBk X pipe magnaflow muffler's. Megasquirt 2 with 36lbs injectors on hurricane intake with 4150 throttle body.Tremec TKO 600 Quicktime blowsheild spec stage 3 clutch. 3.73 gears and still not done
  6. #16
    Join Date
    May 2005
    Location
    Newmarket, ON, Canada
    Posts
    169
    Feedback Score
    0
    Default
    After years of tuning the factory ECU for boost, I would definitely pay the price for the PNP version. It works out about the same costs but gives you so much more including Knock control and the ability to ditch the MAF. If you wish.
    John
  7. #17
    Join Date
    May 2010
    Location
    Worcester. MA
    Posts
    841
    Feedback Score
    1 (100%)
    Default
    If I had it to do over I might go with the gold box
  8. #18
    Join Date
    Apr 2016
    Location
    Mi. 48182
    Posts
    316
    Feedback Score
    0
    Default
    Check my build thread on my 83. I converted my 5.0 from A9L,MAF to MS PNP from EFI Source and love it. I have setup about 5 MS or Pimp conversions on 2.3t motors.
    My 5.0 setup cost me less then $500 and does everything I could ever want. Im not getting ready to install a blower on it next
    Brian R.
    88 2.3t Ranger
    83 TC gt40p motor,Vortech,TFS1 cam,long tubes,MS PnP,T5,8.8,17x9 Cobra 17s
Posting Permissions
  • You may not post replies
  • You may not edit your posts
