Page 6 of 17 FirstFirst ... 234567891016 ... LastLast
Results 51 to 60 of 161
Thread: My 85 TBird
  1. #51
    Join Date
    Dec 2012
    Location
    Apple valley CA
    Posts
    1,754
    Feedback Score
    8 (100%)
    Default
    If you pick up this moths car craf my buddy's 4.6 notch made it in
  2. #52
    Join Date
    Feb 2012
    Location
    Monona, Iowa
    Posts
    471
    Feedback Score
    3 (100%)
    Default
    Finally recieved my custom set of RLCA's from Maximum Motor Sports. Their normal adjustable arms for the Tbirds have a curved tube for the stock length spring. They built me a set with a straight tube so I could use the mustang length spring. They said they would be listing this item for sale on their website.
    I have also been working on the frt suspension to get the 9" svt rims with the 275/40 tires tucked under the fender. I moved the c/c plates inboard 1 inch further than the factory holes would allow. I had to cut out some of the inside of strut towers because the springs were hitting them. Then hauled it across town to the alignment shop to see if I could hit the specs. Was able to get to about 1 degree negative camber, street specs were .5 negative. I was not so lucky on the caster, was only able to get to about 1.3 degrees. I think with some 3/4 in forward offset lower control arms, and moving the c/c plates as far back on the strut tower as possible I will be able to get to the 4.5 degree spec. Once I get some flca's it will be back to the alignment rack to make sure I can hit the specs before the strut towers get rebuilt. Right now the car is set with the RLCA's at the lowest point, so as the car gains some weight I should be able to keep the ride height where it is.
    Also made a bracket to mount the cruise control servo. Utilized two holes aready in the body of the car. This is the area it is located on the 2003 mustang.
  3. #53
    Join Date
    Dec 2012
    Location
    Apple valley CA
    Posts
    1,754
    Feedback Score
    8 (100%)
    Default
    I like the lowers
  4. #54
    Join Date
    Dec 2006
    Location
    Fairfield, Ca
    Posts
    2,074
    Feedback Score
    2 (100%)
    Default
    LUVIN IT !!!
    86' T/C 4.6L DOHC
    16' Chebby Cruze 1.4L Turbo
    “Heavy Metal Mistress”
  5. #55
    Join Date
    Jul 2007
    Location
    port st lucie,FL
    Posts
    1,301
    Feedback Score
    8 (100%)
    Default
    damn fine work, glad to see more birds being cared for, now if they would just show up at some car shows!!!
    1986 T-bird
    347 stroker motor
    185 AFR Heads
    TrickFlow cam 224/232-542/563
    Victor Jr. intake CNC ported
    Quickfuel Holley 800 cfm
    Hooker 1-3/4 long tubes
    Custom built AOD
    B&M 3000 stall
    8.8 w/4.30 gears
    UPR upper/lower control arms
    Strange shocks/struts
    26x10x15 M/T slicks
    11.48@119.27
    (coming soon Tremec 3550)
    The Finished Product
    http://s174.photobucket.com/albums/w...rinnie/T-bird/
  6. #56
    Join Date
    Feb 2012
    Location
    Monona, Iowa
    Posts
    471
    Feedback Score
    3 (100%)
    Default
    Spent about 20 hours going over the cobra wiring harness the last few days. Seperated what's needed and what's not, and started to fit the harness to the car. While it took a long time to cut open the harness and go over the wiring diagrams, there are not that many wires that will need to be hooked up. I am going to use the 2003 mustang battery junction box and ccrm. I have had the pcm reprogrammed to remove the EGR, emission controls, PATS, and set up for a return fuel system. Discovered that the gauges, with the exception of engine oil pressure, are fed info over the same 2 data wires that go to the data link connector, may have to rethink my instument cluster plans. I will post specifics about the wiring when the car is up and running.
    Complete mustang harness
    What's left. The section to the left is the cruise control, starter circuit, and power feed wires into the car. Most of the wires that are labeled in that group are not needed, just not going to depin them until the car is running. Same goes for the bunch to the right near the pcm connector. The longer wires to the right are the wires that power the pcm, data link connector wires, back up lamp, air cond wire to hvac control switch, fuel pump relay trigger wire, and wires to the instrument cluster.
  7. #57
    Join Date
    Jul 2005
    Location
    Pottstown, PA
    Posts
    1,097
    Feedback Score
    8 (100%)
    Default
    Great looking project. Can't wait to see it finished.
  8. #58
    Join Date
    Feb 2012
    Location
    Monona, Iowa
    Posts
    471
    Feedback Score
    3 (100%)
    Default
    Spent most of the evenings this week working on the wiring. Have all the connections temporarily made but the cruise control deactivation wires, need to mount another switch on the brake pedal assy and rewire the clutch position switch. Also reworked my fuel pump mount, used the factory mount for better protection of the pump and wiring.
    Also mounted up the new 3/4" forward offset lower control arms and moved the c/c plates as far back on the strut towers as possible. Maximum Motor Sports thought with this set up I should be able to get about 3.75 degrees caster, a little shy of the 4.5 street setting they recommend, but so much better than the stock setting that it will be fine. Will fit the fenders and tires tomorrow to see how it looks with the tires set forward.
  9. #59
    Join Date
    Feb 2012
    Location
    Monona, Iowa
    Posts
    471
    Feedback Score
    3 (100%)
    Cool
    Mounted up the 2003 mustang swaybar today. To get the motor in I had to cut the original mounts out of the car. The 03 mounts under the rails and clears all the hoses and such under the frt of the 4.6. It also has shorter arms from the body mount point to the swaybar endlink hole for better tire clearence while turning. First had to clean the old mount reinforcement off the rails, then I mocked it up to find where to locate it, moved it as far back as I thought possible. Used the tbird mount that I cut out to mark and locate the holes. Also was able to use the tbird nut-plate and insert it into the rails. Because the k member is shimmed, the swaybar also needs shimmed.
    Old mounting reinforcement with spot welds drilled
    Removed
    Also used old mount for guide to file square hole for clip
    Had to enlarge an existing hole to get nut-plate installed
  10. #60
    Join Date
    Feb 2012
    Location
    Monona, Iowa
    Posts
    471
    Feedback Score
    3 (100%)
    Default
    Was able to get a few things done this weekend. Made a bracket to mount the 03 battery junction box, only issue was to make sure it cleared the neck for the washer solvent tank.
    Installed the new fuel rails, pressure regulator, and ran some fuel lines. Fuel lines are conductive core ptfe that Glenns Performance supplied with the tank, pump and regulator.
    Return lines to regulator.
    Y block and feed lines to back of rails. Still need to run return line up to regulator. Also need to make some more clearance around the fuel lines.
    Also remedied the swaybar endlink angle issue. The 3/8 rod ends look a bit small to me, but are rated at 8500 lbs. Will put some spacers on both sides of the rod end so there is no binding against the bracket or nut, that and some grade 8 bolts with lock nuts during final assy.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
