Page 2 of 17 FirstFirst 12345612 ... LastLast
Results 11 to 20 of 161
Thread: My 85 TBird
  1. #11
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,502
    Feedback Score
    14 (100%)
    Default
    Nice! Can't wait to see it all done up!
    BTW....also the Cobra front control arms are better than the originals...I'm sure you're aware of that though
    '84 and '87 Mustangs
    '98 Explorer
    FORD forever!
  2. #12
    Join Date
    Oct 2004
    Location
    Bloomfield, IN
    Posts
    2,891
    Feedback Score
    4 (100%)
    Default
    Wow! This would be one of my 1st choices for a powertrain swap someday. This should get tons of attention when you get it done and park it somewhere with the hood popped.
    Make sure to post plenty of pics and progress, I can't wait to see this as it progresses.
    '88 'bird, 1-family owned, original 302 converted to HO, T-5 swap, CHE upper/lower control arms, weld-in SFC's, BBK shorty headers & O/R H-pipe, Dynomax mufflers, fox GT tailpipes, Turbo Coupe 8.8 w/3.73's, 11" front brakes, lowered, Tokico Blue shocks/struts, Chuck W shock adapters and motor mounts, 15:1 rack & PS pump, custom alum. driveshaft, chrome '93 Cobra wheels, Falken tires, 20% tint, close to 190,000 miles!
  3. #13
    Join Date
    Feb 2012
    Location
    Monona, Iowa
    Posts
    471
    Feedback Score
    3 (100%)
    Default
    1BadBird
    Nice project!! Looks somewhat familiar although not as powerful....... LOL.... I likey
    I checked out your photos, very nice, thats gonna be one clean engine bay. I had to trim my k member lower mount and relocate the holes , you can just see the front of the orginal holes, didn't look like you had to trim yours.
    ThunderbirdSport302
    Not sure what fCA's I am going to run. I am afraid that with the 03 k member, FCA's, and spindles that the frt track width will be to wide. Thinking I might have to use the 13 inch FCA's from a 93 mustang.
    After mounting the hydroboost I removed the transmission crossmember mounts to move them rearward for the longer T56. Won't know exactly where to mount them until I get the new mount and crossmember bolted in.
    Then I set the motor and trans assy onto the k member and put them on some rollers, lifted the frt of the car and rolled it into place. Ended up having to cut the sway bar mounts out of the car to clear the alternator. Put some temporary 3/8 inch spacers between the upper mount and k member and bolted it in.
  4. #14
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,502
    Feedback Score
    14 (100%)
    Default
    Bad-ass.
    '98 Explorer
    FORD forever!
  5. #15
    Join Date
    Jan 2005
    Location
    Mt. Pleasant
    Posts
    877
    Feedback Score
    2 (100%)
    Default
    I always wanted a Terminator motor in my XR7.... too much $$. So I decided on a 351 with turbo instead. Good luck with your mega swap. It will be sweet when done.
    Travis
    86XR7 in pieces old time with 2.3T 12.96@103.1mph 1.709 60' http://www.youtube.com/watch?v=kGsz7PdEqTI
    88TC basic mods...15 flat @92 on 13psi Redheaded Step child
  6. #16
    Join Date
    Feb 2012
    Location
    Monona, Iowa
    Posts
    471
    Feedback Score
    3 (100%)
    Default
    After getting the motor set in modified the factory mount for the intercooler pump and made a bracket for the body.
    To mount the intercooler i trimmed up the factory brackets and made some tabs to mount it to the frt bumper rebar. Before welding the brackets up I installed the frt cover, used some plywood as a spacer for clearance, positioned and welded on the tabs. Still need to fab up some brackets to help support the rear of the cooler. Was able to use all of the mustang hoses and tubing, just had to shorten the hoses some here and there. It fits really well in the lower grille opening of the turbo coupe cover.
  7. #17
    Join Date
    Dec 2005
    Location
    North Coast
    Posts
    1,410
    Feedback Score
    0
    Default
    Nice work. Lovin' this!
  8. #18
    Join Date
    Dec 2006
    Location
    Fairfield, Ca
    Posts
    2,074
    Feedback Score
    2 (100%)
    Default Nice Work!!
    [QUOTE=bodyman;389872]I checked out your photos, very nice, thats gonna be one clean engine bay. I had to trim my k member lower mount and relocate the holes , you can just see the front of the orginal holes, didn't look like you had to trim yours.
    Ya, I have to trim mine the same as you did yours. I got ahead of myself and painted the k-member before trimming it. I had marked it but ........ I'm liking your progress. Very nice work!!
    John
    86' T/C 4.6L DOHC
    16' Chebby Cruze 1.4L Turbo
    “Heavy Metal Mistress”
  9. #19
    Join Date
    Feb 2012
    Location
    Monona, Iowa
    Posts
    471
    Feedback Score
    3 (100%)
    Default
    Mounting the AC cond was not too bad. Had to make some lower brackets and used the 2003 mustang insulators. Also used the 03 mustang upper mounts and insulators. Had to relocate the left upper mounting hole, widen the support on both sides, and modify the upper support for the extra width. Still need to do some finish work here and there.
  10. #20
    Join Date
    Feb 2012
    Location
    Monona, Iowa
    Posts
    471
    Feedback Score
    3 (100%)
    Default
    Not sure using the 03 mustang rad and tanks were the right decision but I did get them in there, may have been easier to use a rad meant for the t bird and had a custom tank made for the intercooler. I ended up having to drill off the upper half of the lower rad support and replacing it with a piece with less rise. I could get the radiator in there without doing this but there was no room for any type of insulator. If I moved my top mounting plate up any the tanks would not clear the hood. The cap for the intercooler tank comes within 1/4 in of the hood bracing and I did not want to have to cut the hood any.
    Relief is for fan clearance
    Also had to remove the flange from the top of the rad support, better shot of that in the condenser pic.
    Mount to support rear of rad tank
Posting Permissions
  • You may not post replies
  • You may not edit your posts
