Page 2 of 31 FirstFirst 12345612 ... LastLast
Results 11 to 20 of 303
Thread: T-Bird Resto/Mod UPDATE 3-16-18
  1. #11
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,801
    Feedback Score
    17 (100%)
    Default
    Sweet it's finally going to have paint .
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  2. #12
    Join Date
    Dec 2006
    Location
    Fairfield, Ca
    Posts
    2,074
    Feedback Score
    2 (100%)
    Default
    Quote Originally Posted by thunderjet302 View Post
    I know right lol
    I found some very minor damage hidden on the R/S quarter. I also found a couple of rust bubbles that appeared to be minor but after sanding the spots, they look like they will need to be patched, but I'm going to try spot blasting them first.
    I'm puzzled as to why Ford didn't put connectors for the door wiring and also that they didn't allow for window removal without a fight. lol, oh well. I didn't get as much done as I had planned but I did get almost all of the engine bay stripped out. I've got it up on stands and will be dropping the f & r suspensions out, probably next week.....maybe
    86' T/C 4.6L DOHC
    16' Chebby Cruze 1.4L Turbo
    “Heavy Metal Mistress”
  3. #13
    Join Date
    Oct 2007
    Location
    west fork, trinity river
    Posts
    1,589
    Feedback Score
    3 (100%)
    Default
    1BadBird, what did you do use for removing the welding slag?
    As I look at your K-member, the thought keeps occurring, how much weight could be removed from the factory piece w/out affecting structural integrity. Anybody know?
    __________________
    Twin '85 TCs
    White/ Grey 2-tone
  4. #14
    Join Date
    Jul 2009
    Location
    Coral Springs, FL
    Posts
    275
    Feedback Score
    1 (100%)
    Default
    Are those the staggered Mitsu wheels?
    2003 Marauder 300B
    1996-97 Cobra wheel straight but weathered (For Sale)
    84 TC manual shifter handle no knob (For Sale)
    BTW, I had a 1988 T-Bird Sport way back when. I found out that it was totalled shortly after trading it in. It still has the ignition switch recall to date.
    Special thanx to EricCoolCats for showing me to this site.
  5. #15
    Join Date
    Dec 2006
    Location
    Fairfield, Ca
    Posts
    2,074
    Feedback Score
    2 (100%)
    Default
    Quote Originally Posted by RoyLPita View Post
    Ya they are. It has 16X9s and 16X8s. I tried to find another good pair of 16X9s but now it don't matter.
    Quote Originally Posted by t3skidoo View Post
    I just used 2" 3M roto locks, 40 grit then followed by surface-prep pads. I had thought about cutting 2" holes through-out with a hole saw, but who knows, I might get a MM tubular one in the future.
    86' T/C 4.6L DOHC
  6. #16
    Join Date
    Dec 2006
    Location
    Fairfield, Ca
    Posts
    2,074
    Feedback Score
    2 (100%)
    Default Update: More progress Pics
    Ok, now that I have retrieved my camera from the bosses p/u at work, I can post pics the of little bit of progress I've made.
    86' T/C 4.6L DOHC
  7. #17
    Join Date
    Dec 2006
    Location
    Fairfield, Ca
    Posts
    2,074
    Feedback Score
    2 (100%)
    Default Yet more Pics
    Here's a few of the blasted spots
    Granted, those aren't near as bad as some.
    86' T/C 4.6L DOHC
  8. #18
    Join Date
    Dec 2006
    Location
    Fairfield, Ca
    Posts
    2,074
    Feedback Score
    2 (100%)
    Default
    Here is the original k-member. As you can see, there's a lot of holes. I might need to do that cutting I mentioned earlier after-all.
    I still need to strip it down completely. The entire front LSC brake setup is up for grabs as well as the K-member, otherwise it's off to the scrap yard.
    86' T/C 4.6L DOHC
  9. #19
    Join Date
    Dec 2006
    Location
    Fairfield, Ca
    Posts
    2,074
    Feedback Score
    2 (100%)
    Default
    I got a little more done today but nothing pic worthy. I'm raising the car up so I can paint & raptorize the bottom side. While I have the IRS out, my plans are to tear it all down and paint it all and install those 4:30s.
    86' T/C 4.6L DOHC
  10. #20
    Join Date
    Dec 2006
    Location
    Fairfield, Ca
    Posts
    2,074
    Feedback Score
    2 (100%)
    Default A little progress
    Pretty much stripped out now. Just the dash and wiring harness.
    86' T/C 4.6L DOHC
Posting Permissions
  • You may not post replies
  • You may not edit your posts
