Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Stock K-Member Dimension Info Thread
  1. #21
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,375
    Feedback Score
    4 (100%)
    Default
    Well my guy struck out, here is what he had to say:
    "Well I've run into dead ends.... The numbers you gave me are actually service numbers which are different than the engineering numbers which should be stamped on the parts. However was able to cross them back to engineering numbers and got:
    E5SZ-5025-A = E5SC 5025 CG
    E7SZ-5025-A = E7SC 5025 AF
    But unfortunately I couldn't find any usage information or prints in our system. Guessing they are too old and now fall outside our retention window.
    My thoughts on your question are that the k-members should bolt in place of one another, even the mustang k-members should bolt to the t-bird chassis. The difference you'll most likely see is in the location of the lower control arm mounting points do to differences in track, ride height, anti-dive, etc. It's not uncommon for those points to shift slightly over the years with everything else remaining unchanged.
    Mike"
    I replied back and thanked him for looking. I guess it up to the masses to get out there and measure the stock units up. I will see if I can located any stock k-members here locally on my off days and see if I can get some measurements now that it is warming up.
    Darren
  2. #22
    Join Date
    Oct 2004
    Location
    Indpls, IN
    Posts
    8,109
    Feedback Score
    34 (100%)
    Default
    Bumping back to the top.
    Long live the 4-eyes! - '83 Tbird Turbo
  3. #23
    Join Date
    Aug 2006
    Location
    John Deere Country, IA
    Posts
    1,187
    Feedback Score
    2 (100%)
    Default
    The two I have:
    88 Cougar 5.0
    B-23.00"
    C-30.50"
    D-8.25"
    E-Outer - 32.375" Inner - 27.75"
    F- 54"
    04 Cobra
    B-23.00"
    C-30.50"
    D- Front upper - 8.25"; rear upper 8" (needs a 1/4" shim)
    E-Outer - 32.375" Inner - 28.5"
    F- 54"
    Details to make the Cobra fit are here http://www.foxtbirdcougarforums.com/...=18403&page=15
  4. #24
    Join Date
    Oct 2004
    Location
    Indpls, IN
    Posts
    8,109
    Feedback Score
    34 (100%)
    Default
    Some general info grabbed from a Mustang forum.
    As for factory K members, if your R&P is still utilizing the original(to your year) R&P bushings it would be best to stick with the '78-9/'84 K member.
    Also '78-'80 K members the rear inner bolts are closer together than on the later 81-04 cars, which can be rectified to use the later and lighter K members. So.
    '78-'80 direct bolt in.
    '81-'9/84 require rear inner bolt location change to fit.(mod car not K)
    10/84-'88 same inner bolt location mod and use a different R&P sleeved bolt.
    '89-'93 I4 Ks are the same as 10/84-'88 Ks
    '89-'93 V8 Ks have a 1" wider track width. These can be identified by the welded in upper spring mount vs the stamped hole with triangles.
  5. #25
    Join Date
    Oct 2004
    Location
    Indpls, IN
    Posts
    8,109
    Feedback Score
    34 (100%)
    Default
    Resurrecting this. Anyone have new info to share?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
