Page 33 of 33 FirstFirst ... 232930313233
Results 321 to 326 of 326
Thread: Evolution II.....SEFI upgrade ..... updated 10-23-2015
  1. #321
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,283
    Feedback Score
    2 (100%)
    Default
    Im about ready to part out my 86 cougar, lots of miles, but ran like a top. Id imagine the 86 stuff would be easier....
    Quote Originally Posted by jcassity
  2. #322
    Join Date
    May 2007
    Location
    Grand Island, New York (between Buffalo, Niagara Falls and Ontario, Canada)
    Posts
    8,070
    Feedback Score
    14 (100%)
    Default
    Quote Originally Posted by Haystack View Post
    probably the same as what I'm doing with the 87 stuff
    ***** Project "EVOLUTION" 1987 Cougar LS & 1985 Cougar Convertible *****
    5.0 HO 306 roller block, machined GT-40P heads, Wiseco dished forged pistons, Eagle forged floating I-beam connecting rods, Lunati pushrods, ARP bolts, Scorpion aluminum 1.6 rockers, Comp Cams Magnum 266HR, Explorer intake, 65mm TB, MAF Conversion, 19# injectors, Ford Racing stainless P-headers, 2-1/2" cat-less exhaust w/ Flowtech Afterburner mufflers , SC AOD with 2800 BDR torque converter, 3.73 T-Lok rear, CHE rear control arms, full 2-1/2" frame w/1" jacking rails & seat supports, Rear disk brakes, Turbine wheels, All original interior w/ floor shift upgrade .......
    Pretty much every panel on my 87 is new, rebuilt, or re constructed.
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,283
    Feedback Score
    2 (100%)
    Default
    Yeah, but the headlights and dash should be the same harness.
    The 85-86 cars they only ran the wires needed, the 87-88 cars there are a ton more connectors and wiring to make adding options easier.
    Let me know if you need anything.
  4. #324
    Join Date
    May 2007
    Location
    Posts
    8,070
    Feedback Score
    14 (100%)
    Default
    has anyone replaced the dash harness before? is attaching it to the dash frame, and re-installing the dash the best way to go about this procedure?
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,506
    Feedback Score
    14 (100%)
    Default
    That's the way I did mine. Best advice to give is to mount it "loosely" to the connecting points. I used zip ties that weren't quite snug the last time...so if I need to tug on a bundle an inch or so..I could.
    My regret is being EVTM-illiterate, else I'd probably still be playing with the sport.
    '84 and '87 Mustangs
    '98 Explorer
    FORD forever!
  6. #326
    Join Date
    Dec 2014
    Location
    Spokane, WA
    Posts
    109
    Feedback Score
    0
    Default
    What tires & wheels, offset you have mounted on the convertible. Those look nice and beefy in the back. I would like to install the fattest that can fit under the wells and then give it a nascar kind of look with the rims and wide white lettering and maybe a little lowering.
    tbirdregistry.com - #56919
    Lorain, OH. Assembly #151041
    In 1985, Only 811 TBirds followed Mine
Posting Permissions
  • You may not post replies
  • You may not edit your posts
