Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 70
Thread: 3.8/4.2L Split Port Swap into a Fox
  1. #21
    Join Date
    Oct 2004
    Location
    Huntsville, AL
    Posts
    2,105
    Feedback Score
    2 (100%)
    Default
    Quote Originally Posted by jcassity View Post
    sorry to babble so much here jeremy, Let us know which direction you go.
    Any relevant information is good information for the thread.
    I've been recovering from surgeries and complications from said procedures for the past 6 months, so I won't be making much physical progress any time soon.
  2. #22
    Join Date
    Mar 2007
    Location
    apopka fl
    Posts
    405
    Feedback Score
    0
    Default
    Quote Originally Posted by Thunder Chicken View Post
    Excellent info. I've always wondered if a mass-air V6 computer would work with split port. Obviously you'd need one from a DIS car (such as Super Coupe or 94-95 Mustang) as a distributor would never work with an SPI intake. The IRCM system would obviously have to be removed as well...
    the 94-95 mustangs are eec-v with a return style fuel system. imo the 94-95 3.8 are junk 3 sets of headgaskets in 5 yrs.
    louie
    My famous last words:
    It seemed like a good idea at the time. 88TC R.I.P. 88 Sport build in progress
  3. #23
    Join Date
    Oct 2004
    Location
    Huntsville, AL
    Posts
    2,105
    Feedback Score
    2 (100%)
    Default
    Made some progress last weekend. Old engine and transmission are out. New engine is in for test fitment.
    Random findings:
    Broken alternator mount
    Visibly loose bolt on the oil pump
    O2 signal return wire missing insulation
    Also, the NVH weight on the transmission tailshaft was broken, but I've lost my camera-to-computer cable.
    Pulling the old stuff went pretty smoothly except for a rounded starter bolt and transmission removal.
    Upsie-daisy
    Freeeee
    NOT how you want to remove a tranny w/o a plug in the rear...
    [Ace Ventura]Like a glove!
    After I bought the SP engine and did some preliminary measuring I was worried the rear plane of the upper intake might hit the firewall and would definitely hit the discharge hose (although it will be removed eventually) and the vacuum bracket. It ended up fitting perfectly.
    I still need to remove all the old vacuum lines and engine harness. Once completed I can begin figuring out exactly how to re-wire and integrate the new harness.
  4. #24
    Join Date
    Oct 2004
    Location
    Fort Wayne, Indiana
    Posts
    3,224
    Feedback Score
    9 (100%)
    Default
    awesome.
    87 LX 302, E7's, ARP bolts, Mallory Unilite Distributor, MSD 6A, Edelbrock Performer Intake, Edelbrock 600 Carb, Flowtech Long tubes, 5Speed, 8.8w/4.10's, Granatelli Tube K-Member & LCA's, Coil Overs, KYB 4ways, CHE arms, 3" rear drop springs, BBK C/C Plates, SN-95 5-lug stuff, Fuel Cell, Battery Relocation, Mac Mufflers, Stinger Tails, Sunpro gauges, Custom Lip Spoiler
  5. #25
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,501
    Feedback Score
    15 (100%)
    Default
    I hope your documenting this besides this thread.
    Im interested in the resources you got on wiring, evtm or something?
    You should really go electric fan to ,, wont hurt anything.
    GOOD JOB BTW,, finally someone is doing it. That 4 eyed never saw this coming!!!
    what freaking color are those CFI injectors anyway?
    time to take away your paper clip code puller,,lol
  6. #26
    Join Date
    Oct 2004
    Location
    Farmingdale, NY
    Posts
    9,092
    Feedback Score
    18 (100%)
    Default
    I
    Hate
    You
    Looks good! Keep it comin'
    -- 05 Mustang GT-Whipplecharged !! -- 87 5.0 Trick Flow Heads & Intake - Custom Cam - Many other goodies...3100Lbs...Low12's! http://www.fquick.com/V8Demon
  7. #27
    Join Date
    Oct 2004
    Location
    Dunnville Ontario Canada
    Posts
    2,993
    Feedback Score
    1 (100%)
    Default
    very cool, I would like to see how it moves out when it is done....
  8. #28
    Join Date
    Oct 2004
    Location
    Huntsville, AL
    Posts
    2,105
    Feedback Score
    2 (100%)
    Default
    Just mental notes so far. Once I get further along I'll post up solutions to the roadblocks I've found.
    I bought the 2002 Helm wiring manual.
    I'm going to put in an MN12 fan controlled by a DC fan controller.
    Advance Auto specials that I installed after I clogged the inlet filter in my OEM pair.
    Ho-ray for the ability to read engine outputs in real time w/o putting a BoB in!
  9. #29
    Join Date
    Oct 2004
    Location
    Huntsville, AL
    Posts
    2,105
    Feedback Score
    2 (100%)
    Default
    What's the best way to get the engine/tranny in the car?
    I was planning to remove the front clip, and install the engine/tranny together with all accessories on the engine. Will that work? Any tips?
    Also, I need some kind of programmer to kill PATS/EVAP/Rear O2s/etc. SCT looks like a good buy, but I'm not sure which product is what I need. Also, will I need to get a "tune" by a third party to turn on/off those scalars? (unless I have the Pro Racer Package)
  10. #30
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,268
    Feedback Score
    2 (100%)
    Default
    I would pull the side accesories like you did in the first pic, and I would just pull it all out at the same time. I did it with a 5.0 and an AOD, I didn't even remove the ac condenser radiator thingy. I cant remember how much of the front accessories I pulled off though.
    I know it will fit with the water pump, oil pan, and timing chian cover.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
