Page 7 of 7 FirstFirst ... 34567
Results 61 to 63 of 63
Thread: Deciphering Fox Axels
  1. #61
    Join Date
    Oct 2004
    Location
    Indpls, IN
    Posts
    8,131
    Feedback Score
    34 (100%)
    Default
    Quote Originally Posted by ThunderbirdSport302 View Post
    Yes, the complete rear from any V8 Mustang '94 to '98 will work. You'll want to avoid the '99-'04 rears as the axles are longer, though the rear housing itself is identical. Alternatively, you could use a rear from a '99 up and simply throw in ANY axles from a '94 to 98 Mustang, regardless of it being a 7.5" or an 8.8 rear...the axle shafts themselves are dimensionally identical save for the extra inch or so on the '99 up models.
    Actually the 99-04 housing are wider.
    Long live the 4-eyes! - '83 Tbird Turbo
  2. #62
    Join Date
    Mar 2016
    Location
    Miami, FL
    Posts
    2
    Feedback Score
    0
    Default
    ^ thanks for the speedy response, and yea mr mackin had his centerlines widened in the backspacing, i was just concerned if he needed any special work to put a 325 tire out back in the body... a fox mustang nearly requires a tub to fit all that meat back there. as for the brakes, im gonna do some lightweight aerospace brakes eventually and im pretty talented so im not too intimidated by custom brake lines. thanks for the info, looks like this is gonna be a fun project.
    -phil
    theres never enough money to build it right, but theres always enough to build it twice!
  3. #63
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,282
    Feedback Score
    2 (100%)
    Default
    I had 275/60's on my 87 bird with very little rub on a maxed out bump. I thing a smaller then 28" tire would fit fine, and i don't think a 275/50 would rub at all. With a bit it work in sure 325's could fit, but i think that is pushing it a bit.
    Quote Originally Posted by jcassity
Posting Permissions
  • You may not post replies
  • You may not edit your posts
