Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 63
Thread: Deciphering Fox Axels
  1. #21
    Join Date
    Oct 2004
    Location
    Huntsville, AL
    Posts
    2,104
    Feedback Score
    2 (100%)
    Default
    I updated the spreadsheet to account for the bearing race measurements.
    Also, here is a picture of an axle from my '87 7.5" (Taken a few years ago)
    The race goes almost directly to the flange fillet.
    This would lead one to believe the 83-85.5 and 85.5-88 7.5" axles have different bearing race placement and might not be interchangeable. Can anyone confirm/deny this? If all goes as planned, I'll be comparing my '87 axles with '94-'98 and '99-'04 units.
    Preliminary measurement of the '94-'98 axles shows the race going from 25.75" to 27" from the splines.
    Last edited by JeremyB; 09-23-2007 at 11:15 PM. Reason: forum software is sucking, won't show pics in post...
  2. #22
    Join Date
    Aug 2006
    Location
    Two Harbors, MN
    Posts
    2,135
    Feedback Score
    6 (100%)
    Default
    Let's talk housings for a minute, please. So far I see 2 different lengths, 54" and 56". May I ask about where the 10" drum rear fits into this (I have one from an 88 XR7), and how about the Lincoln's housing lengths? Oh, and did anyone confirm the bearing races?
    1987 TC project of infinity
  3. #23
    Join Date
    Oct 2007
    Location
    Manhattan, Kansas
    Posts
    23
    Feedback Score
    0
    Question
    Quote Originally Posted by Jim_Miller View Post
    Car = TBird/Cougar
    Year =1986-1988
    Ring Gear = 7.5
    A = 61”
    B = 56”
    C =
    D = Same as C
    E =
    F = Same as E
    G = 4 Lug
    Car = TurboCoup ONLY
    Year =1987-1988
    Ring Gear = 8.8
    A = 61”
    B = 54”
    C =
    D = Same as C
    E =
    F = Same as E
    G = 4 Lug
    ok i just double checking these cuz i found this on randy's ring and pinion
    Ford 8.8 Years Used on Cougar: (1988 - 1996)
    10 bolt rear cover with 8.8" ring gear. Rear applications have c/clip axles in both 28 and 31 spline. Front applications are in late model IFS Ford's and will have 28 spline axles using CV joints.
    Ford 7.5 Years Used on Cougar: (1980 - 1987)
    10 bolt rear cover with 7.5" ring gear. Has c/clip axles with 28 splines.
    i am just wanting to double check cuz i know that i have a 4 lug open diff i havent check into more but also know the biggest bang for buck will be gears and traction help thanks for the info though
    MAKE IT TAKE IT
    "ELEANOR" 1988 5.0L, IGNITION UPGRADE, STRUT TOWER BRACE, SHOCK TOWER BRACE, ROAD RIPPER 1000 AOD, STILL TINKERING
    "MUDSLUT' 1993 F-150 SUPERCAB FLARESIDE 4X4: STOCK 5.0L, ROAD RIPPER 3000 E4OD, 4.56 gears, Detroit locker rear, Posi-Lok limited slip front, 35X12.50R15 Dick Cepek Crushers, more to come
  4. #24
    Join Date
    Oct 2004
    Location
    Huntsville, AL
    Posts
    2,104
    Feedback Score
    2 (100%)
    Default
    FTBCF >> Randy's Ring & Pinion
  5. #25
    Join Date
    Oct 2007
    Location
    Manhattan, Kansas
    Posts
    23
    Feedback Score
    0
    Question
    Quote Originally Posted by JeremyB View Post
    k reckon i not understand that one lil help plz
    MAKE IT TAKE IT
  6. #26
    Join Date
    Oct 2004
    Location
    Huntsville, AL
    Posts
    2,104
    Feedback Score
    2 (100%)
    Default
    FoxTbirdCougarForums is much greater than Randy's Ring & Pinion
    Which is to say Randy's is wrong.
  7. #27
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,501
    Feedback Score
    15 (100%)
  8. #28
    Join Date
    Aug 2006
    Location
    Two Harbors, MN
    Posts
    2,135
    Feedback Score
    6 (100%)
    Default
    I read this thread again, and I guess SRBird answered my question. The 8.8 88 XR7 is 55.596". It's safe to assume the '83-'92 Ranger axle will only fit the 54" housing. The 1993-97 Ranger/mazda axle shaft is exactly 1" longer than the earlier years axle., and is 28 spline. The explorer is 1/4" longer than that and is 31 spline, and has a diameter of 1.32" (and uses full size Bronco and F150 bearings) So the explorer is out of the question. But, I'd be curious to know the diameter of the 93-97 Ranger shaft, bearing, and bearing race surface(will it allow full engagement into a XR7 housing?). Knowing the dimensions, I can maybe come up with something that requires little machining.
  9. #29
    Join Date
    Aug 2006
    Location
    Two Harbors, MN
    Posts
    2,135
    Feedback Score
    6 (100%)
    Default
    Still trying to get concrete info on the '93 and newer Rangers 8.8 and 7.5 shaft diameters and bearing races. I'm trying to use an 88 XR7 rear with 5 lug and 10" drum without changin the rest of the braking system(cost savings), and I'm waiting for the snow to melt so I can get to the rear end I have. Also, I thought it would be nice to get the info for the 86-88 Tbirds/Cougars with the wider housing and 9" drums. I'm also wondering about any more info on post #21. A sticky is a sticky, but wouldn't it be better with all of the options included?
  10. #30
    Join Date
    Apr 2006
    Location
    Wauseon, Ohio
    Posts
    1,808
    Feedback Score
    1 (100%)
    Default
    V6 mn12's used a 7.5...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
