Page 2 of 7 FirstFirst 123456 ... LastLast
Results 11 to 20 of 63
Thread: Deciphering Fox Axels
  1. #11
    Join Date
    Oct 2004
    Location
    Indpls, IN
    Posts
    8,131
    Feedback Score
    34 (100%)
    Default
    Jim, you're making my head hurt....
    Using the 29-5/32" Ranger axles in the shorter housing gives the same overall width as the Fox Mustangs... 59.5" .... in 5-lug. I have no idea what the length of the other side Ranger axle is....The 29-5/32" dimension is from the splined end to the faqce of the lug flange..... add .75" to that and you're at approx 29.9"....which is the Tbird/SN-95 axle length.
    The Mk7 axles will be .75" + .50" = 1.25" longer than the Fox Mustang axles... Your early Mk7 axle housing is the same width as the Mustang housings...so yes...the longer axles fit in the same housing, even though the resulting overall width is 2.5" wider.
    Long live the 4-eyes! - '83 Tbird Turbo
  2. #12
    Join Date
    Oct 2004
    Location
    Huntsville, AL
    Posts
    2,108
    Feedback Score
    2 (100%)
    Default
    I threw the info into a spreadsheet to make it more manageable.
    I might have gotten all the information correct, I might not have...
    Axle Spreadsheet
    updated 18:30 5/19/08
  3. #13
    Join Date
    Oct 2004
    Location
    Indpls, IN
    Posts
    8,131
    Feedback Score
    34 (100%)
    Default
    Quote Originally Posted by JeremyB View Post
    I threw the info into a spreadsheet to make it more manageble.
    Axle Spreadsheet
    Looks right to me. Glad to see the 99-04 stuff in there too.
    I know Jim has an 84 Mk7 axle, which will be the same as my 84 SVO rear I have in the '80 XR-7.
    There will probably be more than one Mk7 variation.
    Thanks for organizing it better.
  4. #14
    Join Date
    Mar 2007
    Location
    Vancouver, Wa.
    Posts
    778
    Feedback Score
    2 (100%)
    Default
    Quote Originally Posted by Chuck W View Post
    lol Chuck!, my Dad's been telling me that exact same thing for over 40 years!
    If it helps at all let me say I really do appreciate your help and humoring me. Of all the people on this site this would be WAY harder without your help. Seems to all be obvious to you, however confusing for me.
    Jeremy, Wow that looks great Thanks!
    First the comparison of the two, I think I said 2” difference, I was mistaken a bit.. here they are standing side by side
    1990 Mustang Axel
    Overall 29-1/4
    Tip <-->beginning of machined surface (race) 26-1/4
    Tip <-->ending of machined surface (seal) 27-3/4
    1984 Mark VII Axel
    Overall 30-1/2
    Differance is more like 1-1/4
    Also
    The bearing Begins .750 into the end of the housing
    The Backing plate Flange is 1” in from the actual end of the housing (outer edge of the seal)
    The bearing is .625 wide
    I will draw this bering area up tomorrow at work to better illustrate it, right now it’s late and I need to get sleep.
    Objects In Mirror Appear to be Loosing
  5. #15
    Join Date
    Mar 2007
    Location
    Vancouver, Wa.
    Posts
    778
    Feedback Score
    2 (100%)
    Default
    Compairing to Jeremy's info from a ford document (pretty reliable source!)
    It's saying the mustang axels I measured at Overall 29-1/4 (29.250) are actualy 29.180
    I would be measuring .070 longer i think the Keeper grouve and end are much larger than .070 so I'm going to assume my measurment with the tape measure if OFF
    you can bet my Mark VII measurment is off about the same.
    I have a 0-18" calaper at work but nothing to measure 30" any more accurate than what I have.
  6. #16
    Join Date
    Oct 2004
    Location
    Indpls, IN
    Posts
    8,131
    Feedback Score
    34 (100%)
    Default
    Quote Originally Posted by Jim_Miller View Post
    That's what I said above.....
  7. #17
    Join Date
    Mar 2007
    Location
    Vancouver, Wa.
    Posts
    778
    Feedback Score
    2 (100%)
    Default
    You sure did.
    Have never once doubted anything you have said.
  8. #18
    Join Date
    Oct 2004
    Location
    Huntsville, AL
    Posts
    2,108
    Feedback Score
    2 (100%)
    Default
    Excellent information Jim. I've added it to the spreadsheet.
  9. #19
    Join Date
    Feb 2005
    Posts
    93
    Feedback Score
    0
    Default
    I've succeeded at installing an 88 XR7 8.8 inch drum rear end onto my 87 TBird Sport. New quad shocks and diff bushings certainly tightened things up too. Before the install, I measured A = 61 and B = 55.596 as an addition to your spreadsheet. Good spreadsheet. It would be nice to have more of these inter-fox comparison charts developed for our TBird/Cougar modifying obsession (err... I mean hobby).
    87 Sport with HO cam, 19# injectors,TB+Upper Intake,87 Mustang EEC, Cloyes double roller timing chain, Kirban adj. fuel regulator and Autometer fuel pres. guage, HO shorty headers + LSC H-pipe and Dynomax Super Turbo Mufflers, Ford Racing 9mm wires, K&N filter / no air resonator, 8.8 XR7 Diff., V rated tires, Project ongoing.
  10. #20
    Join Date
    Jan 2005
    Location
    Da 'Burgh
    Posts
    275
    Feedback Score
    0
    Default
    Dunno if this pertains to any info being gathered here, but...I was reading the June '07 Car Craft, and they have an article about 8.8" rears. I noticed they mention that starting in '94 mustangs they had 31 spline axles and carrier. I thought the 31 spline axles were in trucks only? Hmm, could Car Craft have made a boo-boo?
    Attached Images Attached Images
    Resident "Idiot".
    Formerly TBob5pt0
    Repairing a lock cylinder that is frozen or sans keys requires a drill, gumption, and a midget on a tricycle.
    Quote Originally Posted by Big_D
    Forgot to put on intake hose when starting the car, sucked neighbors cat into intake.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
