Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Window replacement
  1. #21
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,527
    Feedback Score
    135 (100%)
    Default
    When installing,have the window track raised about half way.Also,remove the inside dew wipe and the window fuzzy on the top middle of the door to give plenty of room to pull the window out..You don't have to touch the motor on the running car.If you need to remove the rivets,and you don't have a drill,borrow one,or take the window to a glass shop and let them do it.You risk breaking the window by not using the right tool for the right job.
    '88 Sport--T-5,HURST shifter,Trick Flow R intake,Ed Curtis cam,Trick Flow heads,Scorpion rockers,75mm Accufab t-body,3G,mini starter,Taurus fan,BBK long tube headers,O/R H-Pipe, Flowamaster Super 44's, deep and deeper Cobra R wheels, Mass Air and 24's,8.8 with 3.73's,140 mph speedo,Mach 1 chin spoiler,SN-95 springs,CHE control arms,aluminum drive shaft and a lot more..
  2. #22
    btwodu Guest
    Default
    AHA!!!!
    I was able to replace the window without removing the bracket at all. It took a long time removing it out of the donor car (until I figured it out) but was maybe a 20 minute job getting it back in.
  3. #23
    Join Date
    Dec 2005
    Location
    Bethlehem,Pa.
    Posts
    4,049
    Feedback Score
    42 (100%)
    Default
    Now you got the know how!,sometimes you got to do it to understand it.
    Old Grey Cat to this.88 Cat,5.0 HO, CW mounts,mass air,CI custom cam,afr165's,Tmoss worked cobra intake,BBK shorty's,off road h pipe, magnaflow ex. T-5,spec stage 2 clutch,8.8 373 TC trac loc,che ajustables with bullits on the rear.11" brakes up front. +
  4. #24
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,527
    Feedback Score
    135 (100%)
    Default
    I pulled mine out of the project car yesterday and fixed it.It was out of the clips.No big deal.i used my epoxy stick made for marine use.It holds tight,dies in two minutes,and it's waterproof,and on my daily driver,it has lasted for a few years.
  5. #25
    btwodu Guest
    Default
    I wish it would have been that easy to fix. I have the bracket with the rivets holding the window in.
  6. #26
    Join Date
    Oct 2004
    Location
    Missouri
    Posts
    8,502
    Feedback Score
    14 (100%)
    Default
    Quote Originally Posted by btwodu View Post
    How do I get the rivets out (I have no drill).
    I had to replace a window on my truck, it had the rivets like you describe, and my drill was at my other farm, didn't have time to get it, so i took a small phillips screwdriver, and a hammer, and gave the inner round part of the rivet a few sharp raps until the thing pushed through, then just take a little pry tool (i used my pocket knife..lol) and pry the little cap dealie off, and you're ready to go...
    bolts are so much easier, damnable rivets
    '84 and '87 Mustangs
    '98 Explorer
    FORD forever!
  7. #27
    Join Date
    May 2008
    Location
    waynesboro
    Posts
    67
    Feedback Score
    2 (100%)
    Default
    on the 87 -88 thunderbirds any idea where i can get replacement clips for the glass, local advance and napa doesnt have them.
  8. #28
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,375
    Feedback Score
    4 (100%)
    Default
    We always found the 83-86 cars with rivets in the salvage yards. Used an 1/8" punch and a small hammer to remove the "stem" of the rivet, cordless drill, and the window was out in about 15-20 minutes. I always reinstalled them with the rivets. I can see where the bolts would be easier but I have a Mac Tools hydraulic hand riveter so the larger rivets were not a big deal to reinstall. I never had to remove the wipes as I just popped the large metal/plastic washers off the bottom of the window while it was still in the door.
    I would suggest removing the felt in the door frame that the window rolls up into and give that a cleaning. Sometimes small fragments of glass get in there when a window is broken out and it will cut some tint up in a hurry.
    Everyone does it a bit different but at least it gets done.
    Darren
Posting Permissions
  • You may not post replies
  • You may not edit your posts
