Technical => Electrical Tech => Electrical Chatter => Topic started by: adamr602 on August 06, 2011, 08:54:59 PM
Title: 1985 Ford T-Bird fuel injectors not spraying
Post by: adamr602 on August 06, 2011, 08:54:59 PM
i own a 85 t-bird 5.0L CFI fuel system and car wont start. i replaced the fuel pump fuel relay cleaned injectors and still cranks but wont start unless i pour gas myself into the carb. would the inertia switch have something to do with this?
Post by: ACCEPT on August 14, 2011, 11:47:39 AM
I have the same problem whith my Cougar 3.8.
I am testing the ECC.
ciao
Post by: Beau on August 14, 2011, 01:02:46 PM
Quote from: adamr602;364700
If it's tripped, then yes, that would be a possible reason why it won't start. Do you know where it is?
