Technical => Engine Swapping => Topic started by: 351fox on March 23, 2017, 04:03:52 AM
Title: How to do a AC delete on a 5.0
Post by: 351fox on March 23, 2017, 04:03:52 AM
I want to take the whole a.c. out of my 88 tbird. Is there a bracket a can buy to do this and not have to remove/ relocate my power steering?
Post by: Haystack on March 23, 2017, 12:59:34 PM
Not really. You could just undo the lines and leave it in place if a relocation bracket is too much work.
Post by: 85CougarCobra on March 23, 2017, 01:38:41 PM
You can do something like this:
https://lmr.com/item/LRS-8511A/mustang-50-ac-eliminator-kit-85-93?year=1993&gclid=CMvq5bOV7dICFRGBswodBJQOHg
Not sure if that is what you are looking for or not as it does move the power steering "up" a little.
Post by: Skunk on March 23, 2017, 02:42:23 PM
You can try to find the PS bracket they used for dealer installed AC. Not sure how the belt clearance and wrap would end up so you may want to search some of the mustang forums.
John
Post by: Haystack on March 25, 2017, 02:03:16 AM
Cougar and mustang brackets are a bit different. Would require a mustang bracket along with the new bracket. Won't find a dealer a.c. add on either, all 302 motors had ac.
Post by: Skunk on March 25, 2017, 07:32:43 AM
I assume you meant all cougar 302s has ac because it was an option for the Mustang.
Bad picture but looks like this:
http://stevesprojects.foxstang.com/wp-content/uploads/2015/10/photo-2-6-1024x768.jpg (http://"http://stevesprojects.foxstang.com/wp-content/uploads/2015/10/photo-2-6-1024x768.jpg")
John
Post by: Beau on March 25, 2017, 01:00:13 PM
It won't work unless you use all the bracketry from the Mustang 5.0, as all of the Bird/Cougar 5.0 sits differently, etc. (closer to the block and heads)..
Post by: jpc647 on May 04, 2017, 11:21:57 AM
I went through the same thing back in 2008. I never was able to find one, so I took all the lines and condensor out, I plugged/caps the fittings on the ac compressor and ran it.
Post by: V8Demon on May 08, 2017, 09:42:26 PM
Quote from: 85CougarCobra;459920
You'll need the Mustang power steering bracket to go with that as well.  Cougarbird ones are different. That won't bolt to the Cougarbird one.  Ask me how I know.
Post by: thunderjet302 on May 09, 2017, 01:12:03 PM
Quote from: V8Demon;460675
Ta Da! https://lmr.com/item/LRS-9998926/50resto-mustang-power-steering-bracket-79-93-5-0
Post by: thunderjet302 on May 09, 2017, 01:15:10 PM
On a side note if you're doing a 5.0 engine swap into a 3.8 or 2.3T car they have all the Mustang brackets available, which will work in a Thunderbird/Cougar  https://lmr.com/item/LRS-10313-K/mustang-engine-accessory-bracket-kit-hardware-7993
Post by: bootleggers deluxe on May 12, 2017, 01:02:25 AM
I'm subscribing to this for when i'm lookingot get the engine back in next fall.
Post by: jcassity on May 23, 2017, 12:06:07 PM
I have an oem original AC Delete bracket with pully I'll never use.
304 772 3411
