Technical => Engine Tech => Topic started by: cougarman on May 04, 2012, 11:20:57 PM
Title: Speed density question...
Post by: cougarman on May 04, 2012, 11:20:57 PM
Just gathering parts and was wondering if the TFS Stage  cam is SD friendly or would I need to go Mass air? Thanks.:D
Post by: thunderjet302 on May 04, 2012, 11:24:42 PM
Quote from: cougarman;389031
No :hick:
If you want to run a TF stage 1 then you definitely need to do a MAF conversion. What heads are you planning on running with the cam?
Post by: cougarman on May 04, 2012, 11:27:02 PM
I'll be using a complete "P" motor. Thanks.
