Results 1 to 8 of 8
Thread: Stuck slip yoke
  1. #1
    Join Date
    Aug 2014
    Location
    camdenton, mo
    Posts
    208
    Feedback Score
    1 (100%)
    Default Stuck slip yoke
    Alright, so it seems my drive shaft is stuck at the slip yoke. How would you guys recommend getting it out?
  2. #2
    Join Date
    Oct 2006
    Location
    Jenks, OK
    Posts
    2,280
    Feedback Score
    4 (100%)
    Default
    Not sure what you mean. Are you referring to the yoke that goes up into the transmission? If so what do you mean by stuck?
  3. #3
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,160
    Feedback Score
    2 (100%)
    Default
    Yeah, it should travel in and out when the suspension goes up or down.
    Take off the driveshaft bolts, and gently tap it out with a hammer. Iver never had one get stuck before.
    Quote Originally Posted by jcassity
  4. #4
    Join Date
    Aug 2014
    Location
    camdenton, mo
    Posts
    208
    Feedback Score
    1 (100%)
    Default
    It's stuck pretty bad this coming week I'm going to use a slide hammer to get it out. Also I have another question are the auto and manual yokes the same length?
  5. #5
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,160
    Feedback Score
    2 (100%)
    Default
    Yes and no. I reused my aod yoke on my t-5. Really, the answer depends.
  6. #6
    Join Date
    Aug 2014
    Location
    camdenton, mo
    Posts
    208
    Feedback Score
    1 (100%)
    Default
    Im guesing the splines got bent on the yoke and I was wondering if I could just use one of these https://www.americanmuscle.com/frpp-...haft-yoke.html
  7. #7
    Join Date
    Aug 2014
    Location
    camdenton, mo
    Posts
    208
    Feedback Score
    1 (100%)
    Default
    I measured and I need a 6" slip yoke
  8. #8
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,160
    Feedback Score
    2 (100%)
    Default
    I've never seen the splines get damaged. I've even chucked a driveshaft out at freeway speeds, pulled over walked back and picked the yoke up off the side of the highway and reused it after.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
