Results 1 to 9 of 9
Thread: Dual Exhaust
  1. #1
    Join Date
    Apr 2018
    Location
    MB
    Posts
    2
    Feedback Score
    0
    Default Dual Exhaust
    I purchaced a 1987 Cougar 5.0L . It came with single Exhaust,..I want to put on duals...Anybody done this on your 87 88 Cougar.??
  2. #2
    Join Date
    Jan 2005
    Location
    Ardmore,Oklahoma
    Posts
    19,522
    Feedback Score
    135 (100%)
    Default
    Throw some stock Fox Mustang headers on it, a Fox Mustang H Pipe, then have the rest added at the muffler shop. The H-Pipe and headers are a simple bolt on, but the mid pipes and tail pipes are different from a Mustang.
    '88 Sport--T-5,HURST shifter,Trick Flow R intake,Ed Curtis cam,Trick Flow heads,Scorpion rockers,75mm Accufab t-body,3G,mini starter,Taurus fan,BBK long tube headers,O/R H-Pipe, Flowamaster Super 44's, deep and deeper Cobra R wheels, Mass Air and 24's,8.8 with 3.73's,140 mph speedo,Mach 1 chin spoiler,SN-95 springs,CHE control arms,aluminum drive shaft and a lot more..
  3. #3
    Join Date
    Sep 2012
    Location
    N.C.
    Posts
    548
    Feedback Score
    6 (100%)
    Default
    +1... Stock mustang headers can be found cheap.
    87 Tbird LX w/Factory floor shifter 3G upgrade. Tinted Windows...85 Mustang GT steering wheel(non-cruise) 17'' Saleen SC style wheels,Front/Rear TC sway bars/poly bushings & Mustang GT steering rack...'05 Mustang V6 springs...93 Cobra MC & booster, MM adjustable C/C plates, Work In Progress....... ( On The Shelf---HO computer, 19lb injectors, HO cam, BBK headers, Explorer Intake, Cold Air Intake ,Phantom Gauges, Stinger stainless exhaust pipes )
  4. #4
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,843
    Feedback Score
    7 (100%)
    Default
    Or, if you're only interested in the look, you can get the 88 v8 cat-back, for what is essentially a single exhaust with 2 mufflers and tails.
    1988 Thunderbird 5.0
    GT40P, TFS-1, KB domes, 30#, MAF conversion, Explorer GT40 Upper/Lower, Smog delete, Wide Ratio AOD Mod, Unlocked Speedo, 3G Charging System Upgrade, Hi-Torque Mini Starter, 3.73 LSD, BBK 1 5/8 unequal headers, H-Pipe.
    88 Thunderbird/Cougar EVTM
    (Thanks to Trinom for hosting)
  5. #5
    Join Date
    Apr 2018
    Location
    MB
    Posts
    2
    Feedback Score
    0
    Default
    Thanks......I want full duals....will see what I can find next week....
  6. #6
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,843
    Feedback Score
    7 (100%)
    Default
    It bears mentioning that the HO headers and H-Pipe setup will require HO oxygen sensors, or 8 inch(?) extensions; as in that setup, the O2s are in the H-Pipe and not the manifolds/headers.
  7. #7
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,754
    Feedback Score
    17 (100%)
    Default
    You can also lengthen the car's oxygen sensor harness (that's what I did). Be sure to solder the wires and not use a crimp connector.
    DO NOT lengthen the oxygen sensor wires themselves. You'll ruin the oxygen sensor that way.
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  8. #8
    Join Date
    Oct 2004
    Location
    Gap Mills WV 24941
    Posts
    14,496
    Feedback Score
    15 (100%)
    Default
    the o2 sensors need 600+ degrees to start making thier own millivolt signal,, how can they do that if they are so far down stream
    is it really that hot on the hpipe?
  9. #9
    Join Date
    Oct 2004
    Location
    Utah.
    Posts
    9,257
    Feedback Score
    2 (100%)
    Default
    Late 86 on the o2 sensors are heated. The 4.6 mustangs have six catalytic converters and pre and post o2 sensors, the post o2's are near the end of the h-pipe.
    Quote Originally Posted by jcassity
Posting Permissions
  • You may not post replies
  • You may not edit your posts
