Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: A/C Restoration - R12 vs R134A, etc
  1. #11
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,845
    Feedback Score
    7 (100%)
    Default
    I'm not taking the front of my shit off so you can say you don't think my condenser looks like an sn-95 condenser. You'll have to take my word for it or move on.
    1988 Thunderbird 5.0
    GT40P, TFS-1, KB domes, 30#, MAF conversion, Explorer GT40 Upper/Lower, Smog delete, Wide Ratio AOD Mod, Unlocked Speedo, 3G Charging System Upgrade, Hi-Torque Mini Starter, 3.73 LSD, BBK 1 5/8 unequal headers, H-Pipe.
    88 Thunderbird/Cougar EVTM
    (Thanks to Trinom for hosting)
  2. #12
    Join Date
    Oct 2004
    Location
    Huntsville, AL
    Posts
    2,094
    Feedback Score
    2 (100%)
    Default
    I'm genuinely curious how a condenser that is 2" taller and 7" wider and drop into the same bracket location.
    Edit:
    Let's be real. You can't.
    http://forums.corral.net/forums/gene...r-79-93-a.html
    http://forums.corral.net/forums/gene...993-stang.html
    http://www.corner-carvers.com/forums...sn95+condenser
  3. #13
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,845
    Feedback Score
    7 (100%)
    Default
    Now that I'm home and looking at it, I moved the brackets, but nothing had to be cut. The upper brackets are both moved outward, the lower are down and outward. I didn't say it popped right in like a direct swap, and I didn't say the bracket locations were the same, I said it fits like OE. OE means using my brackets, maintaining position relative to the radiator, and generally riding in the same position as on the donor car. I moved brackets, for which I had to make new holes; nothing more. I don't know why you had to cut and I didn't, I only know that 8 years ago, the last time I touched it, it was a fairly minor mod to move the brackets.
  4. #14
    Join Date
    Sep 2006
    Location
    Olathe, Kansas
    Posts
    2,408
    Feedback Score
    3 (100%)
    Default
    Quote Originally Posted by TheFoeYouKnow View Post
    SN-95 condensers fit and are optimized for R-134a. Replace all the black o-rings with green ones. Replace the orifice tube with the same color, but when it's on the machine and charged (15% less R-134a than the labeled R-12 capacity), you'll want to adjust the clutch cycling switch on the accumulator until it engages the clutch until 28 or 30 psi on the low side gauge (blue) before it releases. There is a screw down in the connector on the switch to do this with, I like 1/4 turn increments.
    This seems spot on. I have a 88 Cougar 5.0 All stock 88 stuff, new cycling switch and adjusted, Vacuumed down and refilled. Changed nothing else, no leaks, not recharged in 6 years. AC blows very cold and keeps very cool. Mine is a black car in KS summers. If I had to do it again, I would do just what He said above. Fortunately mine worked great stock, just as was.
    Mike
  5. #15
    Join Date
    Oct 2004
    Location
    Huntsville, AL
    Posts
    2,094
    Feedback Score
    2 (100%)
    Default
    Ah, I took fits like OE as fits in the same as OE.
    I had to cut because I used existing holes and made ghetto brackets for it. Drilling new holes to lower the condenser would eliminate cutting the upper radiator support. Two methods to achieve the same end - although I think drilling new holes is the better way to go. At the time, I hadn't found anybody who had done it and the internets yet, so I was on my own for the install - and I don't do well with original thoughts!
  6. #16
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,845
    Feedback Score
    7 (100%)
    Default
    My thought when installing it was that if we assume that the connections are in exactly the same position, but the unit is roughly 7 ish inches wider, the mounts should move out by half that from center. Since the unit is also 2 inches taller (the additional 2 inches is along the bottom relative to the connections), the lower mounts would have to be that measurement lower. 4 3/16 holes and 4 1/4"x 1" lag screws later, we're golden. I moved the radiator away for room to work on the top mounts, then connected the spring locks, and supported the condenser with a stand. It made it pretty simple from there to move it around until the position was right and I made holes with an angle head drill, and ran down lags with an air ratchet.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
