Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Spindles
  1. #11
    Join Date
    Sep 2010
    Location
    Jacksonville, FL
    Posts
    59
    Feedback Score
    0
    Default
    Yeah I've always used the earlier spindles because its what I had laying around, but nothing wrong with later ones as in your case with the supporting mods. Did you go coilover or stay with seperate strut/spring ?
  2. #12
    Join Date
    Jan 2018
    Location
    Chesapeake VA
    Posts
    17
    Feedback Score
    0
    Default
    Thanks guys, yep all the options are confusing, but found a really nice article re Saleen and brakes..the Saleen Mustangs used the Lincoln 5 lug Mk VII rotors and calipers etc. Doing some part number cross checking, these also work on the 87-93 V8 Spindles.
    So I picked up a set of 93 V8 Spindles of a Fox, should be good to go. Thanks.
    Rear is gonna be easy, just havnt decided which way to go, back half, mini tub with coil over n ladders or modified 9 in the stock set up. I have 9 inch center sections already, a narrowed housing. The ultimate goal with this car will be swapping in the 521 BB and Jerico out of my Mustang...turning the bird into a dedicated track car, and putting my 67 back as a street car.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
