Results 1 to 5 of 5
Thread: 84 Tbird Fast Idle Issue - Parts Source???
  1. #1
    Join Date
    Jan 2015
    Location
    Austin TX
    Posts
    4
    Feedback Score
    0
    Question 84 Tbird Fast Idle Issue - Parts Source???
    I have a 84 Tbird with a 5.0L CFI engine. When starting the engine, the fast idle runs too fast - around 3500 rpm. And most of the time the fast idle varies from fast to way too fast. Also, the automatic fast idle kickdown doesn't work. I've narrowed down the problem to the control diaphragm that connects to the thermostat. Does anyone know of a parts source for a replacement pulldown control diaphragm for a CFI engine? Thanks!
  2. #2
    Join Date
    Jun 2005
    Location
    Chicago
    Posts
    10,479
    Feedback Score
    17 (100%)
    Default
    If you can find a part number give these guys a call, they might have it: http://www.greensalescompany.com/
    '88 Thunderbird LX: 306, Edelbrock Performer heads, Comp 266HR cam, Edelbrock Performer RPM intake, Edelbrock 70mm TB, 76mm C&L MAF, 30lb injectors, 2.5" exhaust, AOD with 2800 PI converter, 8.8 with 3.73 gears, 31 spline Traction-Lok, 31 spline Moser axles, 04 Cobra front arms, Maximum Motorsports extreme duty rear arms, subframes.
    '11 Focus, '12 Mustang 3.7, '17 Accord EX-L V6
  3. #3
    Join Date
    Oct 2004
    Location
    Southern Maryland
    Posts
    2,560
    Feedback Score
    0
    Default
    The fast idle cam has three steps. When vacuum is applied to the control diaphragm it should move the idle cam off the highest idle step to the middle step.
    The thermostat, as it warms up, moves it the rest of the way until it drops off the fast idle cam.
    Did you put a piece of hose on the vacuum nipple of the control diaphragm and suck on it? To see if the diaphragm is leaking?
  4. #4
    Join Date
    Oct 2004
    Location
    Southern Maryland
    Posts
    2,560
    Feedback Score
    0
    Default
    I have been trying to remember if the pre-cat converter (pre 1975) carbs had the vacuum pull down (control diaphragm) on the fast idle cam.
    I think they just had the electric choke (thermostat) to move it off fast idle. So, I think your thermostat should move it off fast idle even if the control diaphragm is not working. Just not as fast.
    The thermostat is powered by the stator output on the alternator. It should be 7-8 volts with the engine running.
    Do you still have the stock alternator?
  5. #5
    Join Date
    Oct 2004
    Location
    Southern Maryland
    Posts
    2,560
    Feedback Score
    0
    Default
    pics
    Attached Images Attached Images
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
