Page 5 of 5 FirstFirst 12345
Results 41 to 42 of 42
Thread: Oil Leak - Ideas?
  1. #41
    Join Date
    Feb 2012
    Location
    Grand Rapids, MI
    Posts
    1,758
    Feedback Score
    7 (100%)
    Default
    To start with, you'd be in the market for a transmission that would bolt up to a 5.0.
    1988 Thunderbird 5.0
    GT40P, TFS-1, KB domes, 30#, MAF conversion, Explorer GT40 Upper/Lower, Smog delete, Wide Ratio AOD Mod, Unlocked Speedo, 3G Charging System Upgrade, Hi-Torque Mini Starter, 3.73 LSD, BBK 1 5/8 unequal headers, H-Pipe.
    88 Thunderbird/Cougar EVTM
    (Thanks to Trinom for hosting)
  2. #42
    Join Date
    Oct 2004
    Location
    East Coast Virginia
    Posts
    10,213
    Feedback Score
    0
    Default
    Quote Originally Posted by TheFoeYouKnow View Post
    The 5.0/302/289(from '65)/255/351C&W/240/250/300/3.8/4.2 all share the same bellhousing bolt pattern... Also the early 4.6('91 to mid '92) and a few 400 used same pattern... Anything with a AOD trans is same, as there is only one bolt pattern for those trans(early mod motors used AOD, I had one)... The OP should have a C5, AFAIK those all have the small block pattern...
    BTW the balance on 6cyl is different than v8 so although the transmission bolts up, would need correct flexplate for swapped engine...
    Usually the 6cyl versions are built to a lighter duty standard, so a high milage unit may not be up to v8 duty(at least for long)...
    My other rides (that actually do run & drive)
    1969 Fairlane Cobra 428CJ 4-Speed << New 49th Birthday Picture
    1972 Comet GT - 306 C4
Posting Permissions
  • You may not post replies
  • You may not edit your posts
